Right click the screen, move to Open, down at teh bottom you will see Setup WDM/BDA...
you should have a screen there.. for audio and video..set them to the ATI capture drivers...
click OK.
Right click screen, goto WDM control.
click channel manger, click on auto scan...allow it to scan all the channels available.
Then all you have to do once set up is clcik open and move down to Open WDM or CTRL+W
this should give you the basic setup for WDM TV...
then you can select various setting under video(Advanced) settings, such as Preset, Speed, Preset Quality etc...
Learn to use the right click menus...that is where all your settings are.
If you get stuck let us know. |
