Old September 4, 2008, 09:48 PM
Kayen's Avatar
Default Joining the addiction...
I am now folding as well ...
Joined team 54196 , and i'm under Kayen.
Using F@H 6.20 GPU Client.
I know nothing about folding =/.
So enlighten me ...
Old September 4, 2008, 09:52 PM
Dashock's Avatar
Welcome to the team !!!
1. To get the most amount of PPD only Overclock your Shaders the Memory and Core clock do not seem to give you a higher PPD. ( Energy Saving Tip)
2. (Testing) Cpu core clock does not affect PPD either currently have my cpu downclocked to 1.7 ghz using the Asus Epu-6 Engine software.
Personally i like the software but i would have liked if there was more control of the voltages for the Cpu,Nb as using the turbo mode limits you to depending how high you have left your cpu voltage in your bios. ( Energy Saving Tip)
Overclock your Shaders to the max and btw turn off ce1 support if your cpu automatically downclocks as that effects ppd.
You should get around 6000ppd you can see this by downloading Fahmon.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old September 4, 2008, 09:54 PM
yycraven's Avatar
Welcome aboard, its for a good cause to. As well as addicting
Old September 5, 2008, 06:13 PM
LCB001's Avatar
Folding Captain
So enlighten me ...
Glad to have you on the Team. For an explanation of Folding see Folding@home - Main .
We all have our own reasons for Folding. The points we get make it into a friendly competition but are not why we Fold, they are just an added bonus.
You can check our Team and user stats at Hardware Canucks Forum - Team Summary - EXTREME Overclocking Folding @ Home Stats
Folding For Team 54196
Old September 5, 2008, 08:50 PM
Kayen's Avatar
Thanks guys.
Yep, and my computer is on 24/7 ( i leech exp on my MMO, too lazy to train lol... )
Old September 5, 2008, 09:09 PM
Cptn Vortex's Avatar
Just fired up FAH on my 9800GX2, wow its making some nasty high pitched noise/.....
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old September 5, 2008, 09:13 PM
Dashock's Avatar
Vortex i had the same problem with my 8800GT a noise i never heard before anyways i cant remmber what turned it off but try keeping everything but yer shaders overclocked.
Asus P5Q-E
Corsair Cx600M
Old September 5, 2008, 09:14 PM
My 8800 gts 512 is also making a nasty pitching noise while folding.. hopefully, my comp is the basemant hehe
Back up - Ebay (Inik1) or Heatware
Old September 5, 2008, 09:49 PM
LCB001's Avatar
Folding Captain
According to Flecom at [H] the 'Folding Whine' is caused by the voltage regulator's. Check this GPU client generates high pitched whine from 8800GTX - [H]ard|Forum for info...
Old September 6, 2008, 10:18 AM
Kayen's Avatar
Hm my 9800GTX is not emitting any noises...
The only high pitch sound is my IDE HD.
Anyways so i just fire up F@H and just leave it right?
I downloaded the GPU client off the official site.
