  #21 (permalink)
Old September 7, 2008, 08:29 AM
3.0charlie's Avatar
Originally Posted by Kayen View Post
At first i couldn't find it in the [Username] folder but i figured it was hidden, turns out i had to slap the addy into the bar. Anywho thanks everyone, time to get monitering!
4608 PPD any good?
With the 9800GTX+? It depends - stock, yes. But if you did oc the shaders, then it will keep on rising more.
Hydro-Quebec is salivating...
  #22 (permalink)
Old September 7, 2008, 08:45 AM
Kayen's Avatar
Overclocking the shader hmm... how do i go about that?
  #23 (permalink)
Old September 7, 2008, 09:08 AM
3.0charlie's Avatar
Ok. So ~4600ppd is stock, which is about right. Now for the shaders: d/l Rivatuner, get used to the layout and read this thread: Vaguetech - Rivatuner v2.07-10 Guide. Best one out there. The Creating Overclocking Profiles section will show how to oc the card. For the shaders, simply un-tick Link Clocks and only oc the shaders.
  #24 (permalink)
SugarJ's Avatar
Rivatuner:
RivaTuner v2.10 download from Guru3D.com
  #25 (permalink)
Old September 7, 2008, 10:31 AM
LCB001's Avatar
Folding Captain
4608 PPD any good?
Once you start overclocking the shaders you should be able to get over 6000+ PPD depending on how far you push it.
As a comparison my regular 9800GTX gets between 5800 and 6130 PPD depending on WU...
Folding For Team 54196
  #26 (permalink)
Old September 7, 2008, 10:38 AM
How far should I be able to push my shader on a 8800 gts 512 w/ stock cooling
My current 24/7 OC is 753/1882/1047 or 2094
Back up - Ebay (Inik1) or Heatware
