Old September 6, 2008, 10:23 AM
Supergrover's Avatar
Originally Posted by Kayen View Post
Hm my 9800GTX is not emitting any noises...
The only high pitch sound is my IDE HD.
Anyways so i just fire up F@H and just leave it right?
I downloaded the GPU client off the official site.
Yep!
I would grab f@hmon too.
Welcome to the Fold!
R.I.P.
Old September 6, 2008, 10:38 AM
Kayen's Avatar
I have fahmon but it doesn;t display anything when i open it up =/
Old September 6, 2008, 10:45 AM
You have to "add new client" point it to:
/Users/Supergrover/Appdata/Roaming/Folding@home-gpu
Appdata is a hidden folder.
How to see hidden files in Windows Vista
R.I.P.
Old September 6, 2008, 11:10 AM
Kayen's Avatar
I'm using Windows XP, so where would i have to go for that?
Old September 6, 2008, 12:07 PM
SugarJ's Avatar
Under /documents and settings/gord/appdata.......
Old September 6, 2008, 03:59 PM
3.0charlie's Avatar
That should be "Under /documents and settings/username/appdata..."
Hydro-Quebec is salivating...
Old September 6, 2008, 04:03 PM
sswilson's Avatar
If you goto Start/Programs/Folding @ Home there is a link to "Expert Data Files". Point to the same location as that is.
Old September 6, 2008, 05:30 PM
SugarJ's Avatar
lol. I always put my name down instead of "insert username here". 90% of people can figure it out. But I should probably be more explicit.
  #19 (permalink)
Old September 6, 2008, 05:54 PM
Ditto
Where is the "Anykey"?
R.I.P.
  #20 (permalink)
Old September 6, 2008, 10:19 PM
Kayen's Avatar
At first i couldn't find it in the [Username] folder but i figured it was hidden, turns out i had to slap the addy into the bar. Anywho thanks everyone, time to get monitering!
4608 PPD any good?
