-   HardwareCanucks F@H Team (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/)
-   -   Folding using the Nvidia Client? Heres some Tips (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/9862-folding-using-nvidia-client-heres-some-tips.html)
Dashock September 4, 2008 09:15 PM
Using the Gpu 2 client with Nvidia Hardware ? Here some tips
Hey guys just thought id share a few tips i have found thru my testing of the F@Home Nvidia client im not sure if it will be the same for the Ati client.
1. To get the most amount of PPD only Overclock your Shaders the Memory and Core clock do not seem to give you a higher PPD. ( Energy Saving Tip)
2. (Testing) Cpu core clock does not affect PPD either currently have my cpu downclocked to 1.7 ghz using the Asus Epu-6 Engine software.
Personally i like the software but i would have liked if there was more control of the voltages for the Cpu,Nb as using the turbo mode limits you to depending how high you have left your cpu voltage in your bios. ( Energy Saving Tip)
E3110 @ Stock 3.0ghz and Xfx 8800gt overclocked only on shaders @ 1850
Project 5504(Gives most amount of ppd then the rest)
Project 5504 = 5924.57-PPD and ETA = 1 HOURS 59 MINS
Project 5015(Gives least amount of ppd then the rest)
Project 5015 = 5385.97-PPD and ETA= 2 HOURS 8 MINS
Testing/ Tested cpu at the following:
*E3110 @ 1.7ghz - Results in same ppd on the project but adds 4-6 mins on projects
*E3110 @ 1.8ghz-
*E3110 @ 1.9ghz-
*E3110 @ 2.0ghz- Results in same ppd on the projects but adds no extra time.
*Testings in progress
Basically what this means if everything turns out the way i imagined it would, you can have a bunch of cheap low powered dual core cpus folding with high end Nvidia cards as the Nvidia client gives more ppd then the Ati one for optimal folding.
More tips to come if i find any basically trying to conserve as much energy for anyone that cares.
yycraven September 4, 2008 09:26 PM
Yeah I have only my shaders OCed to 1875 and get anything from 5500 PPD to 6100 PPD
Dashock September 4, 2008 09:41 PM
My shaders die at 1862 so i have them a little less than that you have a good card.
enaberif September 4, 2008 09:46 PM
If you have a single gpu and want even more ppd then run the GPU on core 2 and run a single session console on core 1 and you'll get like 400 more ppd.
Dashock September 4, 2008 09:49 PM
Good tip Enaberif i havent used the cpu client myself as i think i get more outta the Nvidia client and its more efficient but nevertheless a good way of getting more ppd.
enaberif September 4, 2008 09:53 PM
Of course you'll get more.. but any bit counts and if I can get another 400 I'll take it.
yycraven September 4, 2008 09:58 PM
Yeah my card overclocks well. if I want to get high benchmarks can get it at 785/1825/2025.
but running fold I just OC the shaders to its best clock which is 1875. 1900 it runs but I think that's pushing it to much...lol
Inik September 5, 2008 05:56 AM
im doing 5800 PPD.. I should try to oc my shader a bit more :P
SKYMTL September 5, 2008 06:11 AM
Doesn't the GPU2 client work for both Nvidia and ATI cards? Correct me if I'm wrong...
Varroa September 5, 2008 06:31 AM
Yes, it works on both, I am folding on a 2900XT, 3650 AGP and 8800GT OC all with the same client.
