  #81 (permalink)
Old September 7, 2008, 11:19 PM
Dashock's Avatar
Testing whether or not Cpu Overclock/Underclock makes a difference is becoming harder and harder has anyone else noticed same projects sometimes takes longer or shorter time to complete. Ive noticed that the 5015 keep fluctuating in Purticular but it always gives me the same ppd. I wish there was a more like real time accurate ppd recorder.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
  #82 (permalink)
Old September 9, 2008, 04:11 PM
sswilson's Avatar
What I find strange about the Nvidia client cpu usage is the fact that it bumps one core to a solid 100%, but the temps don't jive with it being used that hard. It's almost like the client isn't actually using it, just paid the rent on the space and left it empty.
  #83 (permalink)
Old September 9, 2008, 04:21 PM
3.0charlie's Avatar
Both my Quads are supporting the 280s for folding using only the GPU2 Client (no SMP); the CPU load never goes over 10%.
Hydro-Quebec is salivating...
  #84 (permalink)
Old September 9, 2008, 04:24 PM
sswilson's Avatar
Hrm....
Probably time for me to check out new drivers or something then.
On the E8400 @ 4G running just the GPU client one core is pegged to 100% with the second core alternating between 2% and 4%.
  #85 (permalink)
Old September 9, 2008, 04:43 PM
3.0charlie's Avatar
177.92s, with the CUDA drivers. I just checked, and the CPU usage is ~ 7% on both Quads.
  #86 (permalink)
Old September 9, 2008, 04:50 PM
sswilson's Avatar
Nope... just upgraded from 177.35 to 177.92 and I'm getting the same thing (100% on one core, 2,3,or 4% on the other).
Does anybody know if the client updates itself? Maybe I've got an older version of the client? (vers. 6.20 august 1)
Now I haven't had to do any gymnastics to get this up and running this time around, but I might have changed that INI file (or whatever it was) that was required early on in the gpu client release. Would that do it?
  #87 (permalink)
Old September 9, 2008, 04:59 PM
LCB001's Avatar
Folding Captain
Are you using XP by chance, it's not as efficient as Vista with the GPU client
Folding For Team 54196
  #88 (permalink)
Old September 9, 2008, 05:01 PM
sswilson's Avatar
Yes, most definately still running XP. (See no reason to upgrade.... :) ).
I'll have to do some more digging. It's not a major issue, I seem to be getting around the same PPD as others are reporting, it just seems wierd that it pegs the cpu but doesn't seem to stress it.
  #89 (permalink)
Old September 9, 2008, 05:03 PM
3.0charlie's Avatar
GPU2 Vista Console, 6.20r1 released August 8th (Folding@home - DownloadWinOther; 3rd Client). Core is 1.09, on both rigs. I didn't have to change the .ini file for both setups.
I think there is something about XP vs. Vista CPU usage when folding using the GPU2 Client.
  #90 (permalink)
Old September 10, 2008, 08:16 AM
Eldonko's Avatar
Hardware Canucks Reviewer
There is, SMP will produce a lot more points under Vista vs XP when running GPU2.
