  #61 (permalink)
Old September 7, 2008, 09:35 AM
SugarJ's Avatar
It checkpoints based on time (3-30 min). But if you pause it first, that forces a checkpoint I believe.
  #62 (permalink)
Old September 7, 2008, 05:11 PM
3.0charlie's Avatar
Originally Posted by SKYMTL View Post
Here is one question that I always wondered: will closing down my system mean that I loose all of my work done to that time if I haven't finished a WU with the GPU2 client?
FAH uses checkpoints, which are configurable in the settings: from 5 to 30 minutes. Default is 15 minutes.
If you wish to shut down your rig, first close the FAH window using CTRL+C with the window active. This saves the work done first, before closing; once FAH is re-started, it will continue from the last shut-down - no work lost.
  #63 (permalink)
Old September 7, 2008, 05:28 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Go something interesting here. An 8600GTS + the new 177.79 beta drivers = GPU Client Crash. Same as what happened in the A Not So Small Issue With GPU2 Client thread I started. Seems this client doesn't like some beta drivers.
  #64 (permalink)
Old September 7, 2008, 05:30 PM
Dashock's Avatar
em yea i have never done it like that i usually just pause the work on the gpu2 client and then shut of my computer ? i wonder if it restarts the project when i turn my pc back on.
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
  #65 (permalink)
Old September 7, 2008, 05:31 PM
Dashock's Avatar
Skymtl try using the 177.92 drivers they work well. Unless the drivers you are using is specifically for vista?
Asus P5Q-E
Antec Spot Cool
Logitech X-230
  #66 (permalink)
Old September 7, 2008, 05:33 PM
SKYMTL's Avatar
Haha. I think I have to DL the Cuda drivers, no?
Plus, I think it is only the 177.84 and higher drivers with F@H support.
  #67 (permalink)
Old September 7, 2008, 05:34 PM
Dashock's Avatar
lol that would be the right idea lol the newest one for the 8600gt is the 177.92 works perfectly!
Asus P5Q-E
Antec Spot Cool
Logitech X-230
  #68 (permalink)
Old September 7, 2008, 05:35 PM
SKYMTL's Avatar
Yup...I really think it is the xxx.84 drivers and later with CUDA support
  #69 (permalink)
Old September 7, 2008, 05:39 PM
Dashock's Avatar
did you try the 177.92 drivers with the card you cannot confirm you have see if it plays well ?
Asus P5Q-E
Antec Spot Cool
Logitech X-230
  #70 (permalink)
Old September 7, 2008, 05:53 PM
SKYMTL's Avatar
I have not tried. Just realized I don't have the time to play with this thing right now...
