  #21 (permalink)
Old September 5, 2008, 10:31 AM
These are my stats with mainly using the GPU2 client now:
http://kakaostats.com/usum.php?u=1108503
Once I replace this pos e8600 I'll clock it up again.
  #22 (permalink)
Old September 5, 2008, 10:33 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Originally Posted by Eldonko View Post
Does the Nvidia client even work anymore? I thought it was disabled when GPU2 went live.
No idea. Haven't used it since I got it with the GTX 280. During the summer I just can't see myself adding more heat to my already-hot condo.
  #23 (permalink)
Old September 5, 2008, 10:59 AM
Dashock's Avatar
Would an adminstrator kindly change the name of this thread to "Using the Gpu 2 client with Nvidia Hardware ? Here some tips" Thankyou lol so i wont confuse anyone else
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
  #24 (permalink)
Old September 5, 2008, 11:01 AM
SugarJ's Avatar
The GPU client 6.20 works on both Nvidia and ATI GPU's. But my 8800GT got about 5000ppd using 10% CPU while I'm getting 1800-2400 ppd on my 4870 while using 65% CPU. I got more out of the SMP client. I'm about to give up on F@H again, concentrate on Boincing.
  #25 (permalink)
Old September 5, 2008, 11:32 AM
3.0charlie's Avatar
Why not do both? I'm crunching using the Quads, and folding using the GPUs (nVidia).
  #26 (permalink)
Old September 5, 2008, 11:43 AM
Varroa's Avatar
How many points are you getting using the smp client? I am folding on the same cpu but using the GPU2 client on my 2900XT and getting 2100-2700 PPD. Do you get more using the SMP client?
GAMER: Win7 Pro x64, I7 3770 (stock) (CM 212+), Asus P8Z77-V Pro, XFX 6950 2GB, Corsair Vengeance LP 4 x 4GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Intel X25-M 160GB, 1TB WD Blk, DVD, BRD, HX750W, Auz X-Fi Prelude, Intel Pro CT Gbit NIC & CM Cosmos
Game Server: Win7 Pro x64, AMD Phenom II X4 960T Zosma, Gigabyte GA-MA770-UD3, 2x2GB Gskill DDRII 1000, 640GB WD Blk, 1 ODD, Asus 9600 GSO, Intel Pro PT Gbit, Corsair 400W PS & Antec 300.
  #27 (permalink)
Old September 5, 2008, 11:58 AM
Eldonko's Avatar
Hardware Canucks Reviewer
You can still use SMP with ATI it is just slower. This is 3870 CF and xeon 3110.
  #28 (permalink)
Old September 5, 2008, 02:33 PM
SugarJ's Avatar
Perhaps my earlier statement was confusing.
I currently fold with the GPU client and Boinc with my leftover CPU cycles. My PPD on both have taken a hit since going to the 4870 from the 8800GT. While I was running the SMP client by itself, I was getting about 2850 ppd.
  #29 (permalink)
Old September 5, 2008, 02:38 PM
3.0charlie's Avatar
That's another story and you are quite correct - not much you can do about that: nvidia is kicking Ati's butt big time.
  #30 (permalink)
Old September 5, 2008, 06:39 PM
LCB001's Avatar
Folding Captain
Don't quit folding just yet, the Ati clients are starting to get new larger WU's which make them less CPU dependent. The PPD's are starting to get up around 3850 PPD for a 4870. You might find Folding Forum • View topic - New larger WU (4742-4747 1254 atoms) interesting.
Nvidia folders should check this quote
Re: New larger WU (4742-4747 1254 atoms)
by texaslabrat on Thu Aug 28, 2008 5:15 am
The PPD difference comes from the huge differences in the dependency on the cpu between the two. If you had a liquid-nitrogen-cooled 8Ghz cpu, you could likely match/exceed the nvidia cards' PPD's with a 4870 on the smaller WU's. As the ati cores become less and less cpu-bound through mhouston's work, you'll see that the new WU's being issued for Nvidia will produce smaller and smaller PPD relative to the science being done since the benchmark machine will be doing more ns/day of simulation when the initial PPD mark is set with the more efficient core available at the time. At the end of the day, I believe we'll wind up seeing the PPD numbers matching what our expectations would be given the raw TFLOPS available and the observed efficiency rates of shader use. The Nvidia crowd should soak in the points while they can, because once the larger proteins start being crunched by them, their PPD will likely decrease drastically from what they are accustomed to now just by the fact that the ati client has become more efficient and is the benchmark reference by which everything else is compared to.
At the point where a given WU can be run on the benchmark machine in a non-cpu-bound condition is the point where a true apples-to-apples comparison between the two camps' gpu hardware (and stream computing software stack) can be made.
Folding For Team 54196
