Old September 5, 2008, 06:47 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Originally Posted by Dashock View Post
2. (Testing) Cpu core clock does not affect PPD either currently have my cpu downclocked to 1.7 ghz using the Asus Epu-6 Engine software.
Personally i like the software but i would have liked if there was more control of the voltages for the Cpu,Nb as using the turbo mode limits you to depending how high you have left your cpu voltage in your bios. ( Energy Saving Tip).
Is that so? So that means I can buy a bunch of el-cheapo AMD SLI or Crossfire mobos pair them up with a low-end, energy efficient AMD chip like the 5200+ and have enough CPU processing power to handle folding on the GPUs.
I thought the GPU client was bottlenecked by the processor? Or was that only the first client?
Old September 5, 2008, 07:33 AM
3.0charlie's Avatar
I think it used to be the case, but with the latest Client iterations the CPU clocking does not affect the folding. I saw this since I had my QX9650 running at 4.2, then I down-clocked it back to stock for a Windows re-installation - and that made no change to the ppd output.
Unless that means the QX9650 has enough power at stock speeds to support GPU folding...
Hydro-Quebec is salivating...
Old September 5, 2008, 08:08 AM
yycraven's Avatar
well I went from my E8400 @4.1GHZ down to my E2140 @3.1GHZ and still my PPD are the same.
just the shaders make a difference I have noticed.
still at 6000PPD with my 8800 GT shaders @1875.
Old September 5, 2008, 09:43 AM
Dashock's Avatar
It does not seem to be bottlenecked Skymtl but it does effect ppd but it does add time to the ETA of the project.
My E3110 i downclocked it to 1.7ghz and while it still gave the high ppd it did add about 4-5 mins more on the total time.
I then proceeded to clock it to 2.0ghz which then i found out gave me the same total time as well as the high ppd.
Now i can do more fine testing find out exactly what the lowest processor power you need to give you the same results ill take me a couple days more but for now all you need is a dual core set at 2ghz and you will be fine. I hope it makes sense.
Gonna test the following
Dual Core 1.7ghz- Optimal pdd but Adds 4-5 mins to overall time.
Dual Core 1.8ghz
Dual Core 1.9ghz
Dual Core 2.0ghz- Optimal ppd as well as time.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old September 5, 2008, 09:54 AM
Dashock's Avatar
Doesn't the GPU2 client work for both Nvidia and ATI cards? Correct me if I'm wrong...
And yes your right the client does work on both but i do not know how that client works. Futhermore im not sure if it works the same as the Nvidia one where the Shaders only determine the high ppd so not to comment on it im just focusing on the Nvidia client.
Ill be writing my findings of all my tests on the first page of this thread but i think lol we can save a lot more electricity guys which is hella cool! lol Keep on folding.
Asus P5Q-E
Corsair Cx600M
Old September 5, 2008, 09:56 AM
SKYMTL's Avatar
Dashock, give the GPU2 client a try. I would like to hear your findings versus the Nvidia client.
Old September 5, 2008, 10:06 AM
Dashock's Avatar
I think ive confused you the GPU2 client im using i think is the same as the Nvidia Client i just used the name Nvidia client because i thought thats what we were calling it.
Im just focusing on the behavoir of the Nvidia side of things with the new client
Asus P5Q-E
Corsair Cx600M
Old September 5, 2008, 10:17 AM
SKYMTL's Avatar
Ah, I see. I was wondering since the Nvidia client beta I have bumming around somewhere only had support for Nvidia cards but the GPU2 client supports ATI cards and iGPUs as well.
  #19 (permalink)
Old September 5, 2008, 10:21 AM
Dashock's Avatar
Yep at first i thought it only supported the Nvidia cards but found out the GPU2 client supports both anyways ill just focus on the Nvidia side as i only have an 8800 GT so now that were all on the same boat more testing to come off to work. I so wish i could use the display i remember i think the client you got the beta you were able to show your display it keeps crashing on me when i click display.
Asus P5Q-E
Corsair Cx600M
  #20 (permalink)
Old September 5, 2008, 10:24 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Does the Nvidia client even work anymore? I thought it was disabled when GPU2 went live.
