Uninstall FAH.
Then download the last one of the High-performance client (
Folding@home - DownloadWinOther: 6.22 beta2 for MPICH). Follow the FAQ here (
Folding@home - FAQ-SMP-WinInstall). Make sure you have a login and password setup within Windows.
Once installed, create a shortcut of the FAH executable on your desktop, right-click Properties and change the target by adding "(space)-smp" . Then start FAH, and use the same settings you first used.
You can do this a second time (install FAH in a different folder, and creating a shortcut on the desktop with a different name), and run 2 clients at once. Your Quad can hadle that easily.
Then you can download Fahmon (
Download | FahMon), install it, start it up, right click the client window and add both FAH clients. Then you'll see you Point Per Day (ppd) that your Quad will generate.
Then the addiction will start.
John
