Old July 12, 2008, 05:09 PM
Default Network throttling
Is there any way to reduce how much bandwidth fah uses to upload results? It was hardly noticeable before with the machines taking 1 to 2 days per wu but since i started up a gpu client its bogging down my connection every couple hours now.And its annoying as hell.
Old July 12, 2008, 05:17 PM
Check your router to see if you have QoS and use that.
Old July 13, 2008, 05:16 AM
It doesn't have QoS,ordered one with it though. Hopefully it works better than the qos thats built into windows as it seems to have no effect.
Old July 21, 2008, 10:20 PM
Well it keeps it mostly in check now with the qos router
