  #31 (permalink)
Old June 9, 2008, 04:20 AM
Unklmo's Avatar
question for you guys. what are you running your 'puters at ? i mean i let my main go most of the day yesterday and i saw that my cpu usage was maxed out at 100%.
should i maybe be dialing that back some? right now i left everything at the default setting. what are some of your recommendations?
thnx
  #32 (permalink)
Old June 9, 2008, 04:44 AM
sswilson's Avatar
I'd leave it at 100% unless you find that's not working right for you (problems with other apps, CPU temps too high, etc...).
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
  #33 (permalink)
Old June 9, 2008, 10:54 AM
Scratch's Avatar
and apparently there are bonus points awarded for lowest energy structure also
  #34 (permalink)
Old June 9, 2008, 11:07 PM
Scratch's Avatar
WOOHOOO WE'RE BATTIN 100
  #35 (permalink)
Old June 12, 2008, 09:57 AM
zlojack's Avatar
What's the main reason for doing this over FAH?
Just curious...
[size=3]
  #36 (permalink)
Old June 12, 2008, 11:01 AM
SugarJ's Avatar
Similar to Stanford's F@H, Berkeley's software is much easier to set-up and use, plus you can choose which projects to run. Project Rosetta's goals are similar to F@H, and a few of us kept having WU issues with F@H.
  #37 (permalink)
Old June 12, 2008, 11:04 AM
3.0charlie's Avatar
It's a stable platform. Much more stable... and no WU problems.
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
  #38 (permalink)
Old June 12, 2008, 11:00 PM
Scratch's Avatar
srry Unklmo for the late reply but i also set mine at 100% cpu usage
Unlike FaH I find I can run this client and do most anything BUT high end gaming and thats easily overcome as the BOINC client has a freakin pause button :) which I love
We've topped out at 98 so unless we gain some more recruits this is where we're stayin which isnt too bad considering we have 9 folders atm and we're just a couple places back of team Australias OC club and my old Overclockersclub.com
another great thing about BOINC over FaH is that you still get points if the WU fails for any reason and you can divide your cpu usage between different projects so you could fold for Rosetta, Einstein, Seti, or any number of projects at once
  #39 (permalink)
Old June 13, 2008, 05:28 AM
sswilson's Avatar
Mine hasn't been folding the last couple of days as I'm in Moncton buying a house, and my wife mucked it up trying to get E-mail up and running.
  #40 (permalink)
Old June 13, 2008, 09:05 AM
zlojack's Avatar
Hmmm...
This is intriguing...perhaps I should convert to BOINC...I have both my systems folding 24/7 for F@H right now. A Q6700 and QX9650. Can it be run as a service? On the "family" rig (where I put the Q6700) I run F@H as a service so even when my brother reboots it just starts right back up and I don't have to do anything.
[size=3]
Tags
boinc , folding , rosetta
