Old July 11, 2015, 09:55 AM
Konstantinov's Avatar
Default High CPU temps while F@H?
I have an i7 3960x. Mind you, the ambient temp is probably higher in this room than most people's rooms at the moment, but even with liquid cooling, I'm getting temps above 70 degrees Celsius, up to 73. I don't get that high of temperatures while gaming, so I'm wondering why this happens while folding... I'm not too worried because I'm guessing 70, while undesirable isn't an extremely high temp in the grand scheme of things. It's also for a very good cause.
How bad is 73 degrees and how long can my CPU keep this up for?
It's not the common man that's important at all. It's the uncommon man.
Old July 11, 2015, 10:06 AM
KaptCrunch's Avatar
any pic's of set-up
Old July 11, 2015, 10:29 AM
Originally Posted by KaptCrunch View Post
any pic's of set-up
Not of the inside, no. Decent cable management. Not the greatest but not shabby.
Old July 11, 2015, 10:51 AM
SugarJ's Avatar
Gaming is usually GPU throttled, i.e. your GPU is at 100% while your CPU is at 75%. F@H pegs your CPU at 100%. Use OCCT to test and you'll see the same temps.
That being said, 73 is not dangerous. It's at the high end of my personal comfort zone, but I like to run things a bit cooler.
Old July 11, 2015, 11:58 AM
KaptCrunch's Avatar
placement of fans, rad, etc
Old July 11, 2015, 12:00 PM
I have the radiator at the back of the case (where most exhaust fans are on cases) in a push/pull configuration. I have 2x 200mm fans at the top of the case pulling air out. I have a 200mm fan on the side and a 200mm fan at the front as intake fans.
Old July 12, 2015, 01:34 PM
Folding is taxing the FPUs at max this is why the CPU is getting that hot, all the FPUs in the same time, which is not happening in games.
High temps tianfeng Troubleshooting 14 June 29, 2011 11:02 AM
Still very high temps or not? BFighter Video Cards 11 April 28, 2011 10:12 AM
i5 750: are these temps too high? Jack_Daniels CPU's and Motherboards 11 July 3, 2010 04:21 PM
Temps seem a little high... element291 Air Cooling 28 January 15, 2009 09:33 PM
HDD, CPU temps too high? donimo HTPC Systems & Software 12 June 6, 2008 09:34 AM
