Old November 30, 2013, 08:47 PM
Dr_BenD_over's Avatar
Fallen Folder
Default Er, crap, Help!
Ahhhhh, I just started folding again... totally new gear since the last CC when I last fired up. I just double clicked my old icons to fire it up... I went from Kentsfield to Haswell and a 5850 to 650Ti... Should I be updating something... I think the GPU is using is using a core of my cpu... I didn't think Nvidia cards needed one...
All's well that's Haswell
Old November 30, 2013, 09:13 PM
Fallen Folder
Hmmm, downloaded new client and gpu is stuck at paused...
Old November 30, 2013, 10:44 PM
vandidant's Avatar
Just an idea: In FahControl, set the slider to "Full". The default is medium, and doesn't fold unless idling. Also right click the green text under Folding Slots and make sure they're set to folding.
Old December 1, 2013, 07:29 AM
LoTech's Avatar
I assume you are folding under windows. You have downloaded the new client 7.3.6.
Maybe start here for setup Configuration Guide ? Folding@home
Yes best to have 1 CPU core/GPU.
you can do that under the folding@home client/slots/click on cpu/now click on edit
under there you can set # of cores to fold on. I have i7 2700k 8 cores, but under edit I have set it to 6 for folding as I have 2 Nvidia GPUs folding in my system.
Hope that's a start.
p://www.hardfolding.com/fhtag.php/mem/7984290/26/1.png[/IMG][/url]
Old December 2, 2013, 05:35 AM
Fallen Folder
I got it working properly on my main system, but for some reason the new client doesn't detect the CPU's on my old Q6600 system.
Old December 2, 2013, 05:04 PM
Tim_H's Avatar
Yeah, there is the core requirement with the new core and being opencl. Had to do with the way Nvidia implements it. Have you tried removing the slot, then restarting folding?
HST crap technix Off Topic 50 July 2, 2010 07:30 PM
Holy Crap! somecanadianguy HardwareCanucks F@H Team 6 August 25, 2009 07:23 AM
Crazy GPU PPD, Crap CPU PPD, help please Taz HardwareCanucks F@H Team 5 July 31, 2009 05:37 PM
ms crap again will it every stop gingerbee O/S's, Drivers & General Software 15 April 1, 2009 07:33 PM
Another problem with my crap pc..!!! r0k0 Troubleshooting 22 March 20, 2007 09:23 AM
