Old July 11, 2013, 09:49 AM
Shadowmeph's Avatar
Default not sure if this is worth it or not
every once in a while I take a look on ebay for a supermicro ( g34) motherboard in hopes that I can find either a 2p or 4 p so I can run my spicy chips but I cannot afford 400+ cad
well to day I noticed this Supermicro H8QGI F AMD Opteron 6000 G34 Server Motherboard 16CORE 1TB RAM as Is | eBay
it says it has some bent pins now I am not sure if it is worth trying to fix or not anyone have any idea if it is?
Old July 11, 2013, 10:17 AM
dandelioneater's Avatar
If it says it has some bent pins, then I would ask the seller to give you close up shots of the sockets, if it is more than one or two pins and depending how bad, I would probably avoid it. If you break a pin while trying to straighten it you are more than likely screwed.
Check out that 2nd socket up from the bottom. looks like paste on the socket pins. I would avoid that board unless you can get close up shots before buying. Ask if it still has warranty. Usually SM just has 1 year - so it is probably no warranty left.
my 2cents
ssd, worth it? if so, which one? 16eiverse Storage 4 March 25, 2012 06:39 AM
COD MW2 SP & co-op: worth it? On2wheels Gaming 5 September 2, 2011 10:45 PM
How much is a i7 920 C0 worth now? 0o0 Off Topic 1 May 23, 2010 08:56 AM
Could someone tell me what this is worth? BootlegUsher Off Topic 14 December 19, 2009 02:14 PM
Still worth it? BrokenHalo83 Off Topic 0 April 18, 2009 02:40 PM
