-   HardwareCanucks F@H Team (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/)
-   -   Pre-download Wu? (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/59391-pre-download-wu.html)
Evil Genius Jr. January 28, 2013 04:25 PM
Pre-download Wu?
Is it possible to download say 2-3 Wu at a time? My computer is sometimes disconnected form the internet and the SMP client continually sits there failing at uploading results and downloading new wu (obviously). I'd like to be able to have it still run in the downtime.
Thank!
Tim_H January 28, 2013 07:55 PM
Which version of the client are you using?
If you are using V7 then yes there is(I think). you can add the slot option of max-queue and then the number that you would like to store.
DenisS January 30, 2013 10:02 AM
I guess that would only be good for gpu client only, as smp would be loosing bonus points. Unless I am wrong...
Tim_H January 30, 2013 02:09 PM
no that is correct, the QRB is from the download time.
This could affect the GPU units in the future as well. (The GPU QRB is in the works)
I just need a native linux GPU client that I can run from the command line :)
