Switching From AMD-Intel cpu Well last summer I bought an 2500 i5 that I wanted to switch out with my AMD 1100 6core with but I have been holding off for a few reason . Now I am wonder if the intell will be able to handle my work load because I do Vmfold using 4 cores 24\7 but Plus run 2-3 other OSs in vm that run things on them also those are running 24\7. while those are running I am either surfing the net , gaming or have xbmc to watch some shows. Now will the Intel be able to handle that work load or should I stick with my AMD system? |
Is it a ''non-K'' 2500? You may be better off staying with the 1100T as it has more threads. |
folding wise it is the same, I have a i5 3350 and is doing around 13-14k PPD clocked @ 3.5GHz. I like the i5 setup morte because it is way quieter even with the OEM fan. AMD setups often need good coolers like 212 EVO to keep them silent. |
it is a k but will it be able to handle every thing that will be running in the back ground? |
are you folding vmware linux or windows? AFAIK the windows V7 client still spits out the occasional WU when you have an odd number of cores selected. |
Keep the 1100t and use it as a VM server and use the Intel as desktop. With RDC you can remote to the server from the desktop and control the VM. Hyper-v and ESXi are both free and make nice VM servers |
ya I guess that I could to that as it is though the only system that is inside a case is the AMD 1100t everything else is just sitting on boxes running . |
| All times are GMT -7. The time now is 05:06 AM. |
