I'm running BOINC on the system I have for "my system specs". As for folding the only machine I have right now is my PC at school doing F@H between 7:00 PM and 7:00 AM through some poking with Task Scheduler and FAHClient. The school PC is a Dell Optiplex equipped with a Core i5 2400.
I used to run my secondary rig made up of all parts I didn't care for. That idle computer (sitting in closet) has these parts:
Phenom 9950 / Gigabyte MA770-UD3 / 8 GB (4x2GB) OCZ Platinum / Fatal1ty DDR2 800 5-4-4-18 / Gigabyte GTX 550 Ti / Caviar SE IDE / Lancool PC-K62
The issue with that one is that I don't have enough room to be able to use it. The spot I have for it is wedged between a drawer and a TV so I have to pull the case out to work on it and then push it back in, potentially damaging all the cables (which I've already done once).
__________________ "The computer programmer says they should drive the car around the block and see if the tire fixes itself." [src] |
