  #41 (permalink)
Old November 6, 2012, 08:18 AM
Dead Things's Avatar
Originally Posted by BrainEater View Post
What do you mean , 'stuck with it' ?
If I delete all of v7, I can go back to v6 right ?
Can I just enter my passkey into the v6 gpu clients and qualify for the bonus ?
Yes, and that's probably what you should do. Continue folding regular projects and wait patiently for QRB to complete beta testing. If you start from scratch, though, the client will still fetch the new sucky core. You have to use an existing folding directory that already has a copy of the old v2.22 core in there and to make sure you fold only WUs that do not force the new core (i.e., regular units, not -beta or -advanced).
Kepler, incidentally, needs the new core. Everything else would be better off without it. Eventually, the -beta and -advanced projects will be released full-fah, though, in which case the v2.25 core is coming for us all, whether we like it or not. Hopefully QRB will be ready by then, offsetting the reduced performance of the core with increased rewards per unit.
Join the PPD revolution!
Proud to be Folding @ Home
deadthings @ Team 37412
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
  #42 (permalink)
Old November 6, 2012, 08:34 AM
Originally Posted by sswilson View Post
The only way to get it to work seems to be the process mentioned above.
Incidentally, I've already done the legwork and have a copy of FahCore_15.exe v2.22 if anybody needs it. Unzip the attached and change the extension of the zipped file from .cpy to .exe. Then replace your existing FahCore_15.exe with this one. Note that you can easily tell by the file size which version of the core you are using: v2.22 is about 4.5mb, while v2.25 is about 7.5mb.
  #43 (permalink)
Old November 6, 2012, 08:38 AM
sswilson's Avatar
Can it just be replaced straight out without having to do anything else? (There are two spots where the core might be hiding).
edit: For anybody who's interested, DT's file will be a good start. I couldn't even get the bloody thing to extract properly when I dl'd it from the stanford servers.
  #44 (permalink)
Old November 6, 2012, 08:47 AM
Yup - it's prepped and ready for action (once you have changed the file extension, that is). I've never actually used V7 so am not familiar with where the core(s) may be hiding.
  #45 (permalink)
Old November 6, 2012, 10:22 PM
BrainEater's Avatar
Thx bud .
I didnt need an old folder or anything.I just dumped the renamed core you supllied into the new fah gpu directory , worked right away.
SMP is werkin better too.
I'm doing the same ppd with one card down using v6.....v7 can kiss my ass.
/me loads up gpu 2
Intel 3930k /rIVe/32 Gb vengeance LP/3x eVGA 580's/Intel 520's/WD raptors/etc...
  #46 (permalink)
Old November 6, 2012, 10:45 PM
BrainEater's Avatar
Ok !
yep back up 20 k.
It seems the SMP suffers the most with v7....
  #47 (permalink)
Old November 7, 2012, 02:53 AM
I find the new WUs using A4 core are not really optimized the way core A3s are.
  #48 (permalink)
Old November 7, 2012, 09:02 AM
Don't forget that the extra A4 bonus is a bit phantasmagoric: Folding@home: Bonus for A4-core based projects
Originally Posted by Vijay
To emphasize the scientific importance of these work units, we are boosting the base points of all A4 work units by 10% when uploaded (Note that this bonus will not be reported by V7 or by the 3rd party applications which project PPD but the points will appear when your statistics are credited). The quick return bonuses will be calculated on top of the increased base points.
  #49 (permalink)
Old November 7, 2012, 03:47 PM
BrainEater's Avatar
I've never really cared about 'bonus'.
I do care about "correctly running" tho......My main rig is back to 75k , from the 51k I was getting from version 7.
SMP is up 20% , gpu's are both up 5% on the same unit , and pulling some 24k units...
I do admit I did'nt try to tweak out v7 , but it dun matter....it's fixed.
  #50 (permalink)
Old November 7, 2012, 03:50 PM
Hmm... I'm running 2 WU 8018s on each of my 480s and all of a sudden the PPD from them has gone from 14k to 20k. Now I'm getting a boost for running them. Hence I'm switching back to beta client. That being said, it's running my cards about 8 degrees hotter than a 8000 series WU.
Performance Boost? WhiteAngel CPU's and Motherboards 16 December 27, 2009 02:58 PM
FSB boost or GHZ boost? J2TheROC Overclocking, Tweaking and Benchmarking 14 August 13, 2009 09:33 PM
WIn XP to boost Gaming? jcmaz New Builds 10 April 26, 2009 01:08 AM
Has Anyone Tried Ready Boost? norfolk RAM 5 February 9, 2009 06:08 PM
Why such a huge MFT on my C: drive? Thund3rball Storage 4 March 28, 2008 10:32 PM
