<~----> GPU to get huge boost in PPD - Page 4 - Hardware Canucks
  #31 (permalink)
Old November 1, 2012, 11:23 PM
3x 580s should see an awesome bonus ... :) I've never tried v6, but if its 10k ppd different I may.
  #32 (permalink)
Old November 1, 2012, 11:29 PM
BrainEater's Avatar
Well version 6 is just the individual clients.I use HFM.net for monitoring so all the v7 does is obscure stuff for me....I wanna set flags etc...Like I say I'm 10 k down .That's not cool.
edit : I think the FAH controller of v7 set my proc to -smp 8.......thats not cool , with only 2 580's it runs -smp 12 no problem.
Intel 3930k /rIVe/32 Gb vengeance LP/3x eVGA 580's/Intel 520's/WD raptors/etc...
  #33 (permalink)
Old November 1, 2012, 11:38 PM
I'm having issues with mine now too. I started running the beta work units and I landed this 8018 WU which runs 5 degrees hotter and 2000 PPD less per card. I'm not impressed. I kept my core clock alone and decreased my memory clock to a lowly 1575, then I dropped the core voltage to .900 and it seems I've gained stability and got back down to 72 degrees while only running 70% fan speed. Pretty much back to where I was before. The memory clock drop has 0 effect on folding ppd, or so it seems so I'm going to leave it there. I should be able to run non beta WUs at 60% fan speed and maintain less than 70 degrees with this setup and still fold at 100% power that I had before. Who says 480s run hot?
It's too bad that I can't seperately undervolt my 480s because one of them is much better on low voltage than the other :(
Edit: Just as I clicked send the worst of the 2 cards dumped the WU. I'm going to run the beta on the better performing of the cards.
  #34 (permalink)
Old November 2, 2012, 02:34 AM
Originally Posted by blueem2 View Post
It's too bad that I can't separately undervolt my 480s because one of them is much better on low voltage than the other :(
have you tried EVGA's PrecisionX? I am pretty sure it will allow you to do just that
  #35 (permalink)
Old November 2, 2012, 11:59 AM
Oh you can? That's interesting I'll have to check it out.
  #36 (permalink)
Old November 5, 2012, 03:49 PM
Just wondering if anyone has managed to land any 8057 WUs yet. I'm switching over to the beta client again, problem is it drops my PPD by 4000 unless I manage to get a 8057 unit. I guess it's worth the risk.
  #37 (permalink)
Old November 6, 2012, 05:10 AM
No is not. I an also 2k down on the GTS 450 so going back to FAH gpu tracker for GPU folding and keeping the V7 beta for SMP folding.
  #38 (permalink)
Old November 6, 2012, 07:45 AM
Dead Things's Avatar
There is a reason why your production is tanking. By switching to -beta or -advanced, you've downloaded a project that has forced a core update on you. You've gone from FahCore_15.exe v2.22 to v2.25. The updated core, to put it politely, sucks big floppy donkey dick. And now that you have it, you're stuck with it, and it will reduce all of your GPU production by 20-30%. Unless, that is, you want to go through a rather complicated procedure involving hex editors and such in an attempt to roll your FahCore version back to 2.22: Folding Forum &bull; Login.
edit - I forgot, you have to be logged into FF to see the beta forum, so here's the text from the post I attempted to link...
Downgrading fahcore_15.exe from 2.25 to 2.22 [Fermi]
by k1wi » Sun Oct 28, 2012 4:27 pm
I have successfully downgraded & applied the core manually.
The .fah core that you need to use to downgrade can be downloaded here:
http://www.stanford.edu/~pande/Win32/x8 ... re_15_2.22
Once you have access to it, you need to follow the steps outlined here: http://fahwiki.net/index.php/Downloadin ... s_manually
The file name on the server is Core_15_2.22, note you will need to rename your final file to Core_15.exe (where in the process you choose to do that is up to you).
I chose to access the files from a linux machine and undertook the tail & bunzip2 method listed on that page.
before I copied it to my cores folder, I appended '2.25' to the 2.25 version that was there.
Join the PPD revolution!
Proud to be Folding @ Home
deadthings @ Team 37412
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
  #39 (permalink)
Old November 6, 2012, 08:05 AM
BrainEater's Avatar
Originally Posted by Dead Things View Post
.... You've gone from FahCore_15.exe v2.22 to v2.25. The updated core, to put it politely, sucks big floppy donkey dick. And now that you have it, you're stuck with it, and it will reduce all of your GPU production by 20-30%.
What do you mean , 'stuck with it' ?
If I delete all of v7, I can go back to v6 right ?
Can I just enter my passkey into the v6 gpu clients and qualify for the bonus ?
  #40 (permalink)
Old November 6, 2012, 08:17 AM
sswilson's Avatar
Nope, V 2.25 is now the "new" core and any new install will end up getting it when a WU requires the a15 core. The same holds true for any old install which can't find an a15 core if you delete it from your system. The only way to get it to work seems to be the process mentioned above.
The reaction I got from staff over there when I questioned it is why I'm now boincing rather than folding.
Performance Boost? WhiteAngel CPU's and Motherboards 16 December 27, 2009 02:58 PM
FSB boost or GHZ boost? J2TheROC Overclocking, Tweaking and Benchmarking 14 August 13, 2009 09:33 PM
WIn XP to boost Gaming? jcmaz New Builds 10 April 26, 2009 01:08 AM
Has Anyone Tried Ready Boost? norfolk RAM 5 February 9, 2009 06:08 PM
Why such a huge MFT on my C: drive? Thund3rball Storage 4 March 28, 2008 10:32 PM
