  #121 (permalink)
Old November 16, 2012, 09:26 AM
LoTech's Avatar
Here's a screen grab of my folding client control this morning.
running i7 2700k
evga 560ti ultra classified 448 core
Gigabyte gtx580 SOC (super overclocked)
note the PPD 200K plus.
p://www.hardfolding.com/fhtag.php/mem/7984290/26/1.png[/IMG][/url]
  #122 (permalink)
Old November 16, 2012, 10:43 AM
BeaverBender's Avatar
Yes, but it looks like most of that is coming from your 580... over 140K worth.
Creationists make it sound like a ‘theory’ is something you dreamt up after being drunk all night — Isaac Asimov
All thinking men are atheists — Ernest Hemingway
Faith means not wanting to know what is true — Friedrich Nietzsche
  #123 (permalink)
Old November 16, 2012, 10:56 AM
LoTech's Avatar
True. Most 8057's on 580 get well over 100k PPD.
The 560's I use are both 448 core but different manufacturers.
Usually getting north of 60k PPD on those with a 8057.
This would compare to about 27k PPD on 580 and 15K PPD on the 560's with out the beta flag
  #124 (permalink)
Old November 16, 2012, 11:33 AM
Cptn Vortex's Avatar
Originally Posted by great_big_abyss View Post
Ensure that V7 is set to 'advanced'.
Click "Configure", and enter the "Slots" tab.
Select your gpu slot, and click on Edit.
Under 'Extra Slot Options', click 'Add'.
In the 'Name' box, enter: client-type
In the 'Value' box, enter: beta
Click Ok.
Repeat for all fermi/kepler GPUs that you have.
Hey, do you do this to the CPU slots too? Or GPU only? Is there anything for CPU's to optimize PPD?
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
  #125 (permalink)
Old November 16, 2012, 11:36 AM
great_big_abyss's Avatar
This won't do anything for CPU's. It's only for Nvidia gpus. If you have an AMD GPU, instead of 'beta' you would use 'advanced'. I don't know if there are any optimizations for smp.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
  #126 (permalink)
Old November 16, 2012, 11:52 AM
Well, not in the V7 client anyway.
  #127 (permalink)
Old November 16, 2012, 12:11 PM
Gotcha. Thanks guys!
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
  #128 (permalink)
Old November 16, 2012, 03:43 PM
I'm getting about a 50/50 mix of 8018s vs. 8057s. :) So, Averaging about 180k PPD.
  #129 (permalink)
Old November 16, 2012, 03:49 PM
have a look at QRB for the 8057
https://docs.google.com/spreadsheet/...GaHVIeXc#gid=1
  #130 (permalink)
Old November 16, 2012, 08:00 PM
Ok I made the changes about 2 "projects" ago. PPD is still the same. Is a reboot in order, or does it take a while to Ramp up?
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Performance Boost? WhiteAngel CPU's and Motherboards 16 December 27, 2009 02:58 PM
FSB boost or GHZ boost? J2TheROC Overclocking, Tweaking and Benchmarking 14 August 13, 2009 09:33 PM
WIn XP to boost Gaming? jcmaz New Builds 10 April 26, 2009 01:08 AM
Has Anyone Tried Ready Boost? norfolk RAM 5 February 9, 2009 06:08 PM
Why such a huge MFT on my C: drive? Thund3rball Storage 4 March 28, 2008 10:32 PM
