  #111 (permalink)
Old November 15, 2012, 04:36 PM
Originally Posted by BeaverBender View Post
I'm assuming this will also affect the output of Quadro cards?
needs to be Fermi generation : my GT 430@730 gets 20k PPD on WU8057 and the GTS 450@850 gets around 43k PPD.
  #112 (permalink)
Old November 15, 2012, 11:13 PM
BrainEater's Avatar
The unification of compute cores is overdue.It's a software issue and it's brilliant that Stanford is doing work on this.
The 16-48 (etc) core units (smp) should very definitely be scaleable and measureable VS the 1000+ cores of (gpu) computing.
I'd suggest Stanford learns some valuable information about processor scaling/etc....
edit : .....and yea bout time us GPU guys got some love.
Intel 3930k /rIVe/32 Gb vengeance LP/3x eVGA 580's/Intel 520's/WD raptors/etc...
  #113 (permalink)
Old November 16, 2012, 05:25 AM
makes me think ditching the dual xeon setup. It might be on BST soon.
  #114 (permalink)
Old November 16, 2012, 07:21 AM
Cptn Vortex's Avatar
Is there any special config needed for this? My overclocked GTX 680 is running about 23kppd... Seems a little low compared to the other results above....
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
  #115 (permalink)
Old November 16, 2012, 07:41 AM
great_big_abyss's Avatar
Ensure that V7 is set to 'advanced'.
Click "Configure", and enter the "Slots" tab.
Select your gpu slot, and click on Edit.
Under 'Extra Slot Options', click 'Add'.
In the 'Name' box, enter: client-type
In the 'Value' box, enter: beta
Click Ok.
Repeat for all fermi/kepler GPUs that you have.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
  #116 (permalink)
Old November 16, 2012, 07:47 AM
the communicate stated clearly it was for Fermi only, might not work correctly on Kepler.
  #117 (permalink)
Old November 16, 2012, 07:53 AM
It works on Kepler. I've been getting 8057s on my 680, and they boost my PPD up to 170K.
EDIT: I don't get 100% 8057s, I get a mix of 8057s and 8018s.
  #118 (permalink)
Old November 16, 2012, 08:02 AM
the 8057 units seem to be abundant a lot more during the morning, lest say around 06:00 AM EST.
  #119 (permalink)
Old November 16, 2012, 08:20 AM
The morning is when I get my 8018s. I get most of my 8057s in the afternoon and overnight.
  #120 (permalink)
Old November 16, 2012, 08:26 AM
Aha! Thanks guys, I'll have to make these changed when I get home from work!
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Performance Boost? WhiteAngel CPU's and Motherboards 16 December 27, 2009 02:58 PM
FSB boost or GHZ boost? J2TheROC Overclocking, Tweaking and Benchmarking 14 August 13, 2009 09:33 PM
WIn XP to boost Gaming? jcmaz New Builds 10 April 26, 2009 01:08 AM
Has Anyone Tried Ready Boost? norfolk RAM 5 February 9, 2009 06:08 PM
Why such a huge MFT on my C: drive? Thund3rball Storage 4 March 28, 2008 10:32 PM
