  #101 (permalink)
Old November 14, 2012, 07:03 AM
chrisk's Avatar
Folding Captain
Originally Posted by stoanee View Post
The only thing constant with Stanford is change. As soon as everyone jumps on gpus for folding they will change points...again.
True. CPUs and GPUs do different types of science too, so depending on the type of work that Stanford needs done, the points system gets tweaked again.
Fold for team #54196
  #102 (permalink)
Old November 14, 2012, 08:57 AM
Dead Things's Avatar
It's actually because CPUs and GPUs will now be able to do the same science thanks to the new Gromacs core that QRB is being introduced to GPUs. This way, PG can pursue an ideal of "equal pay for equal work." A noble pursuit in theory, but a perilous one in reality. I explain:
The problem with the equal pay/equal work ideal is that it is precisely that - an ideal. Everybody knows the wide variation in productivity of the same hardware depending on the WU - so the very concept of equal pay/equal work is completely broken in the fah context. For example, when Quicksilver is working on P8102, it produces a 45% higher PPD than when it is working on P8101. So much for equal. Many similar examples on the GPU side of things, lest we forget those 511s. Since both intra-CPU and intra-GPU equality is broken, pursuing equality across platforms will also, necessarily, be broken.
As such, it is an unattainable ideal. The reason this is of some concern is this: Break the points system enough, and eventually it won't work any more.
Join the PPD revolution!
Proud to be Folding @ Home
deadthings @ Team 37412
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
  #103 (permalink)
Old November 15, 2012, 09:25 AM
BeaverBender's Avatar
I'm assuming this will also affect the output of Quadro cards? A Quadro 4000 fell into my lap the other day so I'm wondering what the PPD will be for that.
Creationists make it sound like a ‘theory’ is something you dreamt up after being drunk all night — Isaac Asimov
All thinking men are atheists — Ernest Hemingway
Faith means not wanting to know what is true — Friedrich Nietzsche
  #104 (permalink)
Old November 15, 2012, 09:49 AM
great_big_abyss's Avatar
Try it out, attach the beta flag, and let us know.
Edit: Based on the number of CUDA cores (256) and the clock spd (475Mhz) it should perform similarly to a GTX460SE (288 cores, 650MHZ), which I believe is the core it's based on.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
  #105 (permalink)
Old November 15, 2012, 12:01 PM
SugarJ's Avatar
I finally started getting some of these WU's and climbed into the top 10 in team PPD on the day I had to shut it down and pack it up for the move. Sigh.
  #106 (permalink)
Old November 15, 2012, 12:36 PM
I was #7 in daily PPD, but Braineater bumped me down to #7 just today. Thanks a lot!
  #107 (permalink)
Old November 15, 2012, 01:43 PM
My rigs shut down this morning for about 5 hours :( Otherwise I'd probably have stolen second from Zink already, but by the looks of it stoanee is going to fly by me in no time! :)
  #108 (permalink)
Old November 15, 2012, 02:02 PM
I remember seeing you creep up on me points wise, Blue. I think at one point, you would have passed me in 1.2 weeks. Then I got my new card, and it looks like I'll be able to hold you off for another few monthes. Whew.
  #109 (permalink)
Old November 15, 2012, 02:32 PM
My points are highly inflated from luck getting 8057s. It will settle once they either go away or become the norm :)
  #110 (permalink)
Old November 15, 2012, 04:14 PM
Well, I got second.. Looks like it might only last this update though :)
Performance Boost? WhiteAngel CPU's and Motherboards 16 December 27, 2009 02:58 PM
FSB boost or GHZ boost? J2TheROC Overclocking, Tweaking and Benchmarking 14 August 13, 2009 09:33 PM
WIn XP to boost Gaming? jcmaz New Builds 10 April 26, 2009 01:08 AM
Has Anyone Tried Ready Boost? norfolk RAM 5 February 9, 2009 06:08 PM
Why such a huge MFT on my C: drive? Thund3rball Storage 4 March 28, 2008 10:32 PM
