Old October 22, 2012, 01:06 PM
BrainEater's Avatar
Default What am I missing ?
Ok , so I just put my 3rd 580 back into my rig (in sig).....
The 2 580's that were in did 20-25 kppd each , but now that the 3rd one is in , it's gone to shit.one card does the norm (22k) ones doing 10k and ones at 8k...
I've checked the 'power ' options , I 'think' the 3d setting are ok....Something is definitly not happy tho....I'm off into bios to look....
Intel 3930k /rIVe/32 Gb vengeance LP/3x eVGA 580's/Intel 520's/WD raptors/etc...
Old October 22, 2012, 01:15 PM
SugarJ's Avatar
SLI turned off while folding?
Old October 22, 2012, 01:44 PM
BrainEater's Avatar
Yessir.
I've set all the parameters I did last time , but drivers have changed I guess......I'm missing something.It's like the 2 other cards are 1/2 working.....it's not like 2d clocks.
I'd do a bunch of restarts and checks n stuff , but I've got some steam dl's goin.
Old October 22, 2012, 04:14 PM
LoTech's Avatar
Sounds suspicious to me. I would run a gpu scanner to make sure cards are running 100%. Last time I lost points i had 2 fried cards. Now having said that, I am receiving for the past 2 days a bunch of 8044, 8045 and 8049 WU's they are low points take time and have dropped my one machine to 41,000 PPD from 65000 to 70000 PPD. Cards say 100% but temps on those cards are also lower than normal. I use the evga OC scanner. If you need a copy I can email it to you.
p://www.hardfolding.com/fhtag.php/mem/7984290/26/1.png[/IMG][/url]
Old October 23, 2012, 07:27 AM
BeaverBender's Avatar
I would agree with LoTech, there have definitely been some low PPD GPU work units coming down the pipe lately, so that could be part of it but it does sound like something else is going on. I too would suggest checking to see if they are running at 100% and I would also check the temps... I've seen instances when you add a third card that the temps go above a critical threshold so they then downshift (of course that depends on the settings you are using)
Creationists make it sound like a ‘theory’ is something you dreamt up after being drunk all night — Isaac Asimov
All thinking men are atheists — Ernest Hemingway
Faith means not wanting to know what is true — Friedrich Nietzsche
Old October 23, 2012, 07:37 AM
great_big_abyss's Avatar
I've been getting a low ppd WU on one of my GTX cores for the past 12 hours. I'll have to check the WU# when I get home. It has the same number of points as my usual GTX295 WUs (353), but it doesn't seem to fully utilize the core. Only one core is suffering from this.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old October 23, 2012, 07:47 AM
stoanee's Avatar
Drivers mebbe? My 2WIN did not like newer drivers but I do not have it folding yet so I am not sure if that has been corrected.
heatware
Old October 23, 2012, 07:50 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
CPU bottleneck?
Old October 23, 2012, 07:53 AM
It worked fine for the first 48 hours...then all of a sudden slowed.
Temps on the first core are 71-72 (fully utilized), while the 2nd core has temps of 66-67.
Old October 23, 2012, 01:52 PM
BrainEater's Avatar
Well I tried a variety of things.
eVGA precision reports all cores running 100% , temps to match....2 cards still doing about half of what they should.
If you stop 1 client , the other misbehaving card goes up a little , but still underperforms....
I've ended up removing the 3rd 580 , the other 2 work fine again.
It's almost like it's a pci-e lane issue , but bios reports everything as fine......and the 3rd 580 works just fine in a diff rig.
Am I Missing Something? F@H on Bulldozer SKYMTL HardwareCanucks F@H Team 27 January 11, 2013 05:15 PM
Am i missing something? supaflyx3 Off Topic 4 August 6, 2011 05:15 PM
Am I missing anything? bvsbutthd101 Water Cooling 43 July 12, 2011 05:30 PM
Missing Anna Lpfan4ever O/S's, Drivers & General Software 5 March 20, 2010 12:23 AM
What Am I Missing? El_Fiendo Off Topic 8 October 14, 2009 06:39 PM
