Old October 19, 2012, 08:35 PM
SugarJ's Avatar
V7 does calculate bonus, but which V7 client are you using? It might be an old version that doesn't know Bulldozer exists.
Old October 19, 2012, 08:38 PM
sswilson's Avatar
Could be the latest version has removed it, but this is the reporting I get from V7.....
Old October 19, 2012, 08:39 PM
SugarJ's Avatar
Try the latest beta version available here: Folding Forum • View topic - FAHClient V7.2.9 (8th Open-Beta)
Old October 19, 2012, 08:51 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
How do I find which version I'm using? Or, are there any options that should be checked to include the bonus?
Instead of messing with the V7's viewer, shouldn't HFM just be able to tell me the PPD? If I toggle On the Bonus PPD calculation, it shows ~12K. Shouldn't that be correct?
The version is the only one on their page. V7.1.52 dated March 20, 2012.
Old October 19, 2012, 09:57 PM
I don't know your type of CPU well enough, but you're better off looking at TPF for comparison.
My V7.1.52 FAHControl seems to include bonus; my Gen 1 Phenom can't get 4k PPD without accounting for bonus...
Did you check your passkey, and has F@H counted you as having completed ten SMP2 workunits? Also note that if you happen to have loaded the CPU with something else and slowed down your folding for a little bit, or put the computer in sleep mode, the V7 client's estimate gets humourously inaccurate.
Old October 20, 2012, 06:52 AM
SKYMTL's Avatar
Hmmmm.....how do I check if my passcode is actually working?
Edit: Looks like the points I got from my last WU was only 216.
Old October 20, 2012, 07:16 AM
BeaverBender's Avatar
12K PPD could be correct for your CPU, depending on the WU. What was the number of the last Work Unit you completed, the one you received 216 points for?
Also, can you post a screen capture of the V7 client you are using?
Creationists make it sound like a ‘theory’ is something you dreamt up after being drunk all night — Isaac Asimov
All thinking men are atheists — Ernest Hemingway
Faith means not wanting to know what is true — Friedrich Nietzsche
Old October 20, 2012, 07:17 AM
3.0charlie's Avatar
Count the number of completed WUs (10 minimum), and once you get A3s the bonus kicks in.
If you want to test the chip tpf-wise, and not bother questionning the ppd and the associated bonus, why not use the Folding_for_pscout account and its passkey?
The BGB account can work too (I have both passkeys saved if you need them - shoot me a PM).
edit: for the heck of it I stopped the crunching on my 1090T, and set up SMP using the latest V7 Client (linked by Sugar). 1st WU is a 8049, estimated tpf is 3 mins 18 secs, estimated ppd is 4534.52.
Going to give it a few hours to stabilize itself.
  #19 (permalink)
Old October 20, 2012, 07:18 AM
great_big_abyss's Avatar
This problem seems to have been fixed with the latest release. My V7 does not do this anymore.
'click here to open the Folding@home passkey request Web page'
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
  #20 (permalink)
Old October 20, 2012, 07:52 AM
SKYMTL's Avatar
Can someone remind me what the pscout passkey is?
Am i missing something? supaflyx3 Off Topic 4 August 6, 2011 05:15 PM
Am I missing anything? bvsbutthd101 Water Cooling 43 July 12, 2011 05:30 PM
2x4GB... Am I missing something? Spblue RAM 7 February 1, 2010 11:11 PM
What Am I Missing? El_Fiendo Off Topic 8 October 14, 2009 06:39 PM
Cores missing! BT! CPU's and Motherboards 4 February 10, 2009 05:26 PM
