Old October 17, 2012, 09:23 AM
great_big_abyss's Avatar
Default GTX295 folding
I anticipate this arriving any day now, and I'll want to get it folding ASAP.
This will be my first Nvidia card (ever!!!). What version of drivers will work best for folding with this card? Are the most recent ones okay? Or will I want to use an older release?
I'll be folding with V7 client
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old October 17, 2012, 10:44 AM
Folding on the V7 is not the best idea for this monster, I was using FAH GPU tracker V2 and best drivers that I folded with were 260.99 which are WHQL also. They will let you run other apps and use it as display card without showing any lag, even if you are watching movies. But you might want to disable the SLI which windows or the drivers enable by default. For the moment I am not using it as doing SMP and GPU drops the production too much on SMP to justify that, I am ;osing 20k PPD production on SMP while the card does 15-16k. I also noticed that Intel platforms are much more sensitive and loose more points while folding SMP and GPU that compared to AMD platforms. I am getting a flexible 1x to 16x riser adapter and will connect the GTX295 on the Opteron rig to see how it fares, without making it a display card. Display will be done by a GT 520 on regular PCI port.
Old October 17, 2012, 11:55 AM
I am only doing GPU folding with this rig. It is also used to watch media and surf the web. If not v7, which is the best client to use?
Old October 17, 2012, 12:13 PM
I just said : FAH GPU tracker V2. look here FAH GPU Tracker V2 - Home
Old October 17, 2012, 12:35 PM
Ah, okay. Sorry, I wasn't around during those folding days, so I didn't know gpu tracker was a thing. I'll figure it out, thanks
Old October 17, 2012, 03:37 PM
LoTech's Avatar
Can you run GPU tracker and v7 in conjuction? Use gpu tracker for gpu's, and v7 for cpu only. Just wondering.
Also to chime in on the drivers. I am now using the most recent Nvidia drivers, and to be honest I never really see a big difference in PPD from drivers. I see the big difference in PPD with the WU's that are shipped to me. Some have TPF's of 53 secs and some have 8 mins or more, geez. I also notice that some have long tpf's with little points awarded and some have short tpf's and larger points awarded. To me it seems like they are not awarded fairly for the amount of time and power required on some of these WU's. SHould they not award you more points for the harder units to crunch through?? Just a thought.
p://www.hardfolding.com/fhtag.php/mem/7984290/26/1.png[/IMG][/url]
Old October 18, 2012, 08:19 AM
Tim_H's Avatar
Why not?
Old October 18, 2012, 08:29 AM
Tim_H's Avatar
To your first question, yes. You can configure V7 to only control the CPU, that said the V7 client should handle the gtx295 just fine (might want to dissable SLI as marstg said). It's already one of the whitelisted cards.
The drivers can have an impact on desktop performance/lag I'm only folding on one GPU right now, and if i remember correctly I'm running the latest drivers. There is some lag and mouse jumping on the desktop to the point where I will stop folding while I'm using the machine then start it when I walk away.
Points, there's a topic. points can swing a lot from one unit to the next, even within the same project number. I have seen smp wu's on some of my machines that will produce 16000ppd, then the next one is 33000ppd. To me it's just luck of the draw. The only way to get consistent ppd from one unit to the next is to have a system exactly the same as the one they use for benchmarking units when they are new.
Old October 18, 2012, 07:06 PM
Different drivers make the card behave nice or not, makes no difference for the PPD. The only difference is done if the card used to fold is also driving your display, that is all. 260.99 was the only driver that would allow me to have no lag at all while folding on it in the same time. I tried it with GTX 460 , 9800GX2, and GTS 250 and all the time the experience was very good. Now I am no longer GPU folding (for the moment) so i am not using it anymore. I might get a GTX 470/480 and do some more GPU folding during the autumn/winter/spring.
Old October 19, 2012, 05:56 PM
I'm trying out V7. Got both cores folding, no problem. 260.99 drivers. No apparent lag when using my machine for surfing/media. No idea on PPD, V7 isn't displaying any WU points.
And yowza, does this thing ever get hot... that's a lot of hot air being dumped inside the case.
Powersupply for GTX295 (folding) great_big_abyss Power Supplies 26 October 12, 2012 08:01 PM
gtx295 and 9800gt in the same rig phil3_66666 HardwareCanucks F@H Team 22 February 4, 2010 06:03 PM
4 x GTX295 -working- fefox HardwareCanucks F@H Team 69 October 23, 2009 12:57 AM
[WTB] EVGA GTX295 Liu Kang Buy/Sell & Trade 7 July 3, 2009 07:29 AM
