Old October 17, 2012, 10:15 AM
G777's Avatar
Originally Posted by Shadowmeph View Post
The fahmon is a POS I just fired up HFM and it is reading around 7556 a redit of 22607 man now I am hugely disappointed not even sure if it is worth running this thing if I am only going to be doing that little, I might as well just shut it down and run my main PC with VB and fah running in the back ground probably get close to the same result.
As Tim_H said Running regular -smp you should be fine, not sure of the ppd but I'm sure it will be much more than 7556
Old October 17, 2012, 10:39 AM
Oh yeah, just no -bigadv anymore. For -bigadv it would need a pair of hexacore Intel xeons at least at 3.5GHz and on native linux install, as for AMD this is left only for the 4P machines now.
Old October 18, 2012, 08:08 AM
Tim_H's Avatar
I'd say for ppd it should be somewhere in the 40k+ range.
Old October 18, 2012, 08:56 AM
Shadowmeph's Avatar
well I am going to try those and if there isn't any real significant change then I am going to look for a new project where my server can actually do some more good.
which other projects are out that that my server can actually do better?
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Something wrong with my cpu? overlords CPU's and Motherboards 36 January 17, 2011 06:56 PM
Is something wrong howpet HardwareCanucks F@H Team 16 May 4, 2010 08:57 AM
Am I doing something wrong? boggtrotter59 HardwareCanucks F@H Team 15 March 19, 2010 10:12 AM
What went wrong? punk_zappa Troubleshooting 11 June 20, 2009 10:31 AM
Something wrong? paphman910 Off Topic 2 December 19, 2008 05:43 PM
