  #21 (permalink)
Old July 12, 2012, 11:16 AM
gingerbee's Avatar
welll my 24 threader is still getting crappy ppd but on to another question with v7 can i run smp and still fold on my gtx 580 that's in the the htpc specs are i7 2600k with 12 gb ram and the gtx 580. should i be able to get better ppd with just the i7 folding or should i use both since i can't get bigadv any more on the i7 thanks once again for any and all help
  #22 (permalink)
Old July 12, 2012, 03:01 PM
Tim_H's Avatar
With Windows, Yes. You can do both SMP and GPU folding. The losses that you get to the SMP client should be compensated for(and then some) with the extra output from the 580.
Never hurts to try all of the combinations and see what gets the most points. I'm going to say that running both will have the best output.
  #23 (permalink)
Old July 13, 2012, 10:55 AM
MARSTG's Avatar
I am losing 2k PPD folding on 965 when I activate the 450GTS, (down to 5k from 7k) but the GTS alone does 10k PPD so is ok, it compensates a lot.
6 GPU folding computer/need help with dedicated folding machine Silent_Avenger New Builds 11 December 25, 2011 02:17 PM
360 Case Mod of the Gods, “XBOX Supreme”... Mnpctech Off Topic 4 June 17, 2011 01:17 PM
AND PPD WILL SUFFER , THUNDERED THE FOLDING GODS!! _dangtx_ HardwareCanucks F@H Team 39 February 21, 2010 11:51 AM
All of Gods Creatures, Big or Small Soultribunal Off Topic 9 December 13, 2009 07:44 PM
Question for SKYMTL !!!! (or other PSU gods) Delavan Power Supplies 21 February 6, 2009 04:17 AM
