-   HardwareCanucks F@H Team (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/)
-   -   Problem getting started. (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/54810-problem-getting-started.html)
W4ff1e June 16, 2012 08:20 AM
Hey guys, just setting up to fold and ive got the client running in the tray for my gpu (gtx 680) but its not running any WU's.
i5-2500k
Z68 ud3h mobo
Stock 680
win 7 ultimate 64bit
is there anything i need to set up further and/or configure properly?
Also any logs i can post to help find the problem?
sorry 4 being a total newfag @ this.
Shadowmeph June 16, 2012 09:12 AM
Has it downloaded the wu's yet? I am not sure how to do Graphic card folding but what I would do is restart it and see if that works.
W4ff1e June 16, 2012 09:44 AM
Well its been running for an hour or two now so I would assume the WU isnt that big, heres the most recent copy pasta from the log if it means anything to anyone.
[15:33:58] + Processing work unit
[15:33:58] Core required: FahCore_11.exe
[15:33:58] Core found.
[15:33:58] Working on queue slot 01 [June 16 15:33:58 UTC]
[15:33:58] + Working ...
[15:33:58]
[15:33:58] *------------------------------*
[15:33:58] Folding@Home GPU Core
[15:33:58] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[15:33:58]
[15:33:58] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:33:58] Build host: amoeba
[15:33:58] Board Type: Nvidia
[15:33:58] Core :
[15:33:58] Preparing to commence simulation
[15:33:58] - Ensuring status. Please wait.
[15:34:08] - Looking at optimizations...
[15:34:08] - Working with standard loops on this execution.
[15:34:08] - Previous termination of core was improper.
[15:34:08] - Going to use standard loops.
[15:34:08] - Files status OK
[15:34:08] - Expanded 46722 -> 252912 (decompressed 541.3 percent)
[15:34:08] Called DecompressByteArray: compressed_data_size=46722 data_size=252912, decompressed_data_size=252912 diff=0
[15:34:08] - Digital signature verified
[15:34:08]
[15:34:08] Project: 5766 (Run 8, Clone 153, Gen 958)
[15:34:08]
[15:34:09] Entering M.D.
[15:34:15] Tpr hash work/wudata_01.tpr: 1850702999 1592491603 2738160153 3566804070 2324515530
[15:34:15]
[15:34:15] Calling fah_main args: 14 usage=100
[15:34:15]
[15:38:05] Gpu type=2 species=30.
Tim_H June 18, 2012 09:43 AM
The GTX 680 is not supported by the v6.4x client to my knowledge. you will need to install the V7 client and if i recall you need to use the beta flag to get the 680 to work. I don't have one myself but I have seen some conversations about them.
dandelioneater June 18, 2012 09:49 AM
This might be helpful: http://www.evga.com/forums/tm.aspx?high=&m=1526339&mpage=1#1548388
