Old June 14, 2012, 08:28 PM
Default A bit of help.
Hey all! I have my new computer built, and I thought what the heck, I can give my night away for folding.
However, I am in need of some help. I cannot for the life of me get Folding@Home to see my MSI Twin Frozr III 7850. Even when set to SMP and GPU, it only uses the CPU. I know AMD's arn't as good as NVIDIA's when it comes to folding, but I would rather still have my GPU mine along side just my CPU. Anyway, could someone help me configure this?
Old June 15, 2012, 01:56 AM
SwingOP3's Avatar
Among some of the issues that AMD cards have in regards to Folding@Home one major one is that they use too many cpu cycles to be of any significant benefit without much tweaking and experimenting. What you may gain in ppd with the AMD card you'll loose on the cpu side - no net benefit. You'll be better off simply folding with the cpu only.
But this is my opinion.
Old June 15, 2012, 11:00 AM
Totally agree. An AMD client can consume 25% of cpu, where a nvidia client uses around 1-2%. Nvidia cards doesn't hurt too much the SMP ppd, but i can assure you the AMD will!
Old June 15, 2012, 12:52 PM
great_big_abyss's Avatar
Hmmm, that may depend on the PPD of both. My 1055T gets between 6-8k PPD, while my 7950 does about the same - 6-8K PPD. Now, even if I shut off my GPU, I may gain 20-25% on my CPU, that's up to an additional 2K PPD, but I'd be losing up to 8K PPD, that's a net loss of about 6K PPD...
Anyways, to the OP, which client are you using? Are you using V7? What version of video drivers do you have installed? Do you have 'Client-Type: Advanced' set up in V7?
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
