Old April 7, 2008, 06:05 PM
magictorch's Avatar
Default Hlpwith SMP client
I downloaded SMP client 1.01 for use with an E6750.
Im having trouble getting the install bat to initiate at the account/password stage. Do I need to have username registered before I can set this up?
I dont use a password for windows login and wondered if there was a conflict there also.
Hope you can help,
Typical attempt:
Go to install bat---loads MPICH@ process manager...then lists my account: not sure what to put here? so i put my name-then asks for password-make one up- and it says unable to connect.
Old April 7, 2008, 06:16 PM
werty316's Avatar
That is the problem.
In order to use the SMP client you must have your windows account set with a login and password.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old April 7, 2008, 06:37 PM
magictorch's Avatar
yep-ok created a new user and in ok now. What teamname should I enter?ill have a quick look anyway--plus how do you set it to fold at 80%-nearly there!! cheers,
Old April 7, 2008, 06:56 PM
3.0charlie's Avatar
Team number is 54196. In the options select Advanced options (Yes) you will find CPU usage requested; set to 80.
If unsure, you can follow Step 2 here: Folding@Home SMP Console Install - DigiWiki.
Old April 7, 2008, 07:50 PM
magictorch's Avatar
great thanks
