-   HardwareCanucks F@H Team (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/)
-   -   I have an "Unknown" question (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/54363-i-have-unknown-question.html)
LoTech June 1, 2012 07:03 PM
My question is why does the v7 control list gpu WU's as :
Base Credit unknown
Estimated Credit unknown
Estimated PPD unknown
Estimated TPF unknown
The smp is fine. The gpu is a GT 9800 running on winxp professional 32 bit with an I5 650 or 750 4 core cpu, no HT. No OC's and my Total PPD is about 6800 listed. The units appear to be running fine in the log.
Thanks
sswilson June 1, 2012 09:52 PM
Is it only one WU? If so, it's probably just not in the database... that can either be because it's a new WU that hasn't made it in yet, or an older one that's been removed from the database, but ended up needing a few runs to clean up a hole in the data. If it's every possible WU that might indicate a different problem.
LoTech June 2, 2012 06:16 AM
Unknown
It is only the one WU. But I keep getting them on the one PC. The other day I set up folding on a older PC to see what it would do. It has the first gen. i5 4 core cpu. and a gt9800 gpu. For about the past 3 days I have received a 5xxx wu always comes up Unknown. The current wu is:
5767 (9,241,4830)
FaHcore 0x11
PPD says on average(for 3 days) 5500-6000.
If it says unknown but appears to be running fine, do I get any credits for the wu?
3.0charlie June 2, 2012 06:18 AM
Yes you should. As Steve mentioned the cause is probably the WU not added to the database. No worries.
LoTech June 2, 2012 07:47 AM
Thanks for the replies. I shall keep an eye on it.
