  #101 (permalink)
Old January 25, 2008, 08:36 AM
Mr. Cipher's Avatar
I'm running two command-line clients now. I went through and installed them in two different directories, assigned affinity through the setup and changed the registry settings. It's all good now! Thanks :)
I wish I understood why some people have low WUs and wickedly high points, and then people like myself have low WUs and very little points. Either way, I barely notice it now (command-line vs. gui)
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | BFG GTX 295 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Intel E1xxx & E2xxx OC Thread
  #102 (permalink)
Old January 25, 2008, 09:02 AM
3.0charlie's Avatar
It depends which client you are using. GUI<command-line client<SMP Win<SMP Linux, and somewhere in there the GPU client. A major factor also is the CPU you are using, since the WUs assigned are different depending how many cores FAH recongnizes.
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
  #103 (permalink)
Old January 26, 2008, 11:25 AM
Mr. Cipher's Avatar
I D/L the FAH504-console, I don't know if that is the SMP client or not.
I have an e2180 @ 3.4ghz at the moment.
i7 Red
C2Q Blue
  #104 (permalink)
Old January 28, 2008, 07:09 AM
lcdguy's Avatar
That would be the regular console client. The SMP client identifies it self as an smp client in the name. Also the installation process is longer than the regular client.
Did you carpe your diem ?
  #105 (permalink)
Old April 20, 2008, 04:22 PM
Cptn Vortex's Avatar
Hey all, my quad rig is taking a little break.... turns out my somewhat gimped Maximus board is now fully Gimped....It wont last a day running....whenever I come home from work it's still running, but I cant get a display... I feel so dumb now for when I forgot about that silly mobo standoff that was definitely in the wrong place..... Oh well, just means spending more money!
The Vortex H20
EVGA SR-2 Classified
2 x Xeon L5639 Hexcore CPUs, 3.2GHZ
EVGA GTX 580 - 940/2115
24GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 90GB Corsair Force SSD RAID0
Sharp 32" Aquos 1080p
Benq W500 Pojector.
Watercooling:
2 x EK Supreme HF, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, XSPC GTX 580 FC block, EK Coolstream XT 220 RAD Gelid Wings Push - CM R4s Pull.
  #106 (permalink)
Old September 7, 2008, 10:50 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Of course, now I am trying to get into Folding a bit and naturally I have some questions.
First of all, my CPU client is currently working on the "Amber" core. I have never heard of this core but it looks like it will take FOREVER to complete (even with a QX9770) while only netting me 171 points. Is this normal?
Next of all, in FAHMON, the CPU client shows itself in Yellow instead of the normal green. Does that signify an error?
Am I using the right client with the standard CPU client (systray client) downloaded from the main F@H page?
  #107 (permalink)
Old September 7, 2008, 10:53 AM
sswilson's Avatar
What client are you running? If it's the console client, then yeah, they take forever (relative to the GPU or SMP client) to finish. I use the console on my quad GPU/Console/Rosetta setup but that's only to take up the slack on the two cores I'ved dedicated to GPU folding.
Edit:
Yellow signifies that it's not sure if you'll finish the WU in time. You'll almost always see that when you first start the folding client.
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
  #108 (permalink)
Old September 7, 2008, 10:54 AM
SugarJ's Avatar
You want the SMP client from this page:
Folding@home - DownloadWinOther
  #109 (permalink)
Old September 7, 2008, 10:57 AM
SKYMTL's Avatar
I think I found my problem. The GPU client is eating up about 37% - 50% of my CPU usage when runing. WTF?
  #110 (permalink)
Old September 7, 2008, 11:00 AM
sswilson's Avatar
That's normal.
Tags
f@h , fah , folding , folding @ home
XP pro or home? mgp141 CPU's and Motherboards 18 January 6, 2008 08:07 AM
XP Home sub $100!!!! sswilson Computer & Electronics Hot Deals 11 October 16, 2007 12:06 PM
Home Theatres, Whos Got One ? lcdguy Off Topic 11 May 10, 2007 01:12 PM
Home Security Shadowed Reviews & Articles from the Web 0 April 23, 2007 02:05 PM
Microsoft Home Server D1GGY Networking 2 March 7, 2007 07:58 PM
