  #41 (permalink)
Old October 15, 2012, 07:01 AM
zincvidia's Avatar
Trial Member
I had the same issue with V.7 FAH client as draemn, but after a bit of forum hopping tried FAH GPU Tracker V2 and it started folding... usually around 20K PPD.
  #42 (permalink)
Old October 15, 2012, 07:45 AM
Tim_H's Avatar
Want to try the new beta version of V7? says that it's supposed to support Fermi, and update the gpu.txt file automatically.
Folding Forum • View topic - FAHClient V7.2.9 (8th Open-Beta)
  #43 (permalink)
Old October 15, 2012, 08:32 AM
SugarJ's Avatar
Will try tonight and let you know how it works for me.
  #44 (permalink)
Old October 15, 2012, 08:34 AM
sswilson's Avatar
I haven't looked all that deeply into the beta, but if memory serves correctly it's just the whitelist that's been updated to include kepler. You'll probably still need to use the Client type Beta switch to get it to fold.
  #45 (permalink)
Old October 18, 2012, 08:22 AM
SugarJ's Avatar
I downloaded and installed the 8th Beta linked above last night, and my 680 was up and folding immediately.
I did add the client-type beta flag in case it was just the WU that worked, will report back tonight.
  #46 (permalink)
Old October 18, 2012, 08:36 AM
sswilson's Avatar
Unless times have changed what happens without the beta flag is that the WU appears to start and pegs power @ around 50% but the WU never advances to 1%.
  #47 (permalink)
Old October 18, 2012, 08:52 AM
Tim_H's Avatar
Good to hear, I don't suppose you want to try it without the beta flag, see what happens?
  #48 (permalink)
Old October 18, 2012, 10:02 AM
SugarJ's Avatar
It appeared to advance to 6.5% before I figured out how to add the beta flag. I did not check the log though.
Sure, I'll try it out. I'll take the beta flag out tonight and see what happens.
  #49 (permalink)
Old October 18, 2012, 11:38 AM
SwingOP3's Avatar
Any ppd numbers?
  #50 (permalink)
Old October 18, 2012, 07:38 PM
SugarJ's Avatar
Appears to be 20k ppd on a 8018 WU with TPF of 3:57. My points from today would back that up, as my total PPD according to FAH Control is supposed to be 70k, and I've submitted 53k points so far since midnight.
I just removed the client-type beta flag, and let it run. Went through 4 frames when I was on the phone, so I'll leave it and see how it does overnight.
