-   HardwareCanucks F@H Team (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/)
-   -   v7 client keeps failing (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/53986-v7-client-keeps-failing.html)
Adzsask May 5, 2012 10:37 AM
I downloaded the v7 fah control console lastnight SMP&GPU version, and this morning I see the GPU portion failed in the night. Any ideas? it for sure was not temps, CPU peaked @46C, GPU 63C.Was not a failed overclock either all running @ stock settings. I have successfully folded with SMP on CPU, and GPU2 GPU clients on there own with no failures.
Adzsask May 5, 2012 02:27 PM
Well launched it again and again at %2X it hard locked my PC this time instead of failing, baffling.
chrisk May 5, 2012 02:32 PM
Make sure only one client is running, and perhaps try different drivers (if you have ruled out heat)
stoanee May 5, 2012 02:39 PM
Which project was it on when it failed?
PerryC May 5, 2012 03:23 PM
I have found with my V7 client that the monitor can not be turned off, whether I physically shut it off or the power saving features shut it off. A screen saver coming on that is all black is fine, as long as the monitor doesn't turn off or go to sleep. Also I have found that if I pause a the client HFM will report the WUs as failed when in fact they haven't failed.
Adzsask May 5, 2012 04:02 PM
7808.
Adzsask May 5, 2012 04:04 PM
changed my power settings so the monitor stays on and restarted the project we will see if that helps, don't use a screensaver.
Hmmm, now my GPU isn't being used, just SMP8 folding now, before it was SMP&GPU at once, not liking this new v7 client at all.
Adzsask May 5, 2012 04:11 PM
This has went from baffling to frustrating, quit and restarted the client, now it is GPU&SMP8 folding...is this right with the SMP&GPU client?
stoanee May 5, 2012 04:17 PM
I use the v7 client for smp & the older v6 client for gpu folding. Even so, once and a while, a 7xxx gpu project will not send itself once it completes. I have to close & restart it, then it sends itself off.
Adzsask May 5, 2012 05:30 PM
Well made it to %63 so far with this 8019, all i changed was my screen not turning off, and raising priority of FAH client.
