Old May 6, 2012, 06:39 AM
Adzsask's Avatar
Perry C gets a cookie!, he troubleshot my problem from another Provence! leaving the screen on was the cure, kind of odd I can't turn my monitor off now, I have shuffling backgrounds now to keep my screen from getting any burned in images. Even paused it a couple times, and still finished and got my points so I think that it is fixed.
Old May 6, 2012, 07:19 PM
PerryC's Avatar
Glad I could help, but I can't take full credit. Somebody mentioned it one of the threads here when I was frustrated with the same issue. Unfortunately I can't remember who or what thread. Then I went looking in a couple of other places and the monitor issue was mentioned a few times. Gave it a try and solved my issues.
The only other issue I have noticed, like I said in my previous post, is that if you pause a client HFM will report the WUs in progress at that time as failed when they really haven't failed.
The oath to serve your country did not include a contract for normal luxury, and comforts enjoyed within our society. On the contrary it implies hardships, loyalty and devotion to duty, regardless of rank
Old May 7, 2012, 05:16 AM
I think it also solve my issues! My PC was crashing and I could not wake up the display. I'll report tonight if it's still good :)
Back up - Ebay (Inik1) or Heatware
Old May 7, 2012, 06:37 AM
Yep it was this thread: GPU3 goes to sleep after a WU is completed
I haven't had any issue manually turning off the monitor (or now in my case, TV), but with the 295 and up series of nVidia driver your F@H GPU units go down the drain when Windows tells your screen to turn off. If you have a plasma or something that you think will get images burned into it, you can use screensavers for their (old) intended purpose.
Old May 7, 2012, 08:25 AM
great_big_abyss's Avatar
Does anyone know if this is an nvidia problem, or if AMD cards are also affected. I haven't noticed anything, but maybe that would explain the low ppd of my 7950.
Old May 7, 2012, 08:26 AM
Adzsask's Avatar
ya I read that post, but I have paused several times in the last two days, and completed every wu, honestly if it didn't pause I would have went bck to using two older clients, but I have paused one unit a good 25 times just as a test, plus I wanted to play WOT. I see I got the credits for the project so it seems to be working for me.
Old May 7, 2012, 08:28 AM
Adzsask's Avatar
Good question, not to sre I never dared folding on my AMd set ups (CF 5870, and CF6970) Both setups ran super crazy hot and I had to basically use a box fan as a side panel on my pc case to play games longer then 30 minutes without overheating.
Old May 7, 2012, 08:47 AM
I'll try disabling monitor automatic display off this evening. From what I understand, I can manually turn off the TV (which I'll have to, my pc is hooked up to an HDTV until I can get my desk set up, and it consumes a boatload of power) and not affect anything. So, I'll do that (I always wondered if the zerocore function would affect folding) and see if my ppd increases dramatically. Then again, maybe zerocore would only activate it the card wasn't functioning. I guess we'll find out in a few days.
  #19 (permalink)
Old May 7, 2012, 09:31 AM
PerryC's Avatar
I never had this issue with my HD5750, however I haven't folded with that with the latest V7 client (0.9.548 or something like that I think.)
  #20 (permalink)
Old May 7, 2012, 01:09 PM
BeaverBender's Avatar
This is only an nVdia problem... as it is related to the new driver releases from them.
Sapphire 6950 2GB Fan failing w0z Video Cards 1 March 28, 2012 07:51 AM
ACC 0% 12% -12% what do these do? Core 0 always failing 0o0 Overclocking, Tweaking and Benchmarking 1 February 16, 2010 07:56 PM
I think my 8800GT is failing! doup93 Troubleshooting 15 July 17, 2009 07:23 PM
harddrive failing. help please kyle_L Troubleshooting 2 May 10, 2009 06:44 PM
TF2 Failing? Infiniti Gaming 7 July 11, 2008 01:39 PM
