  #41 (permalink)
Old April 3, 2008, 06:10 PM
3.0charlie's Avatar
Yup, even though it is not mentionned, assume this is the 32bit version - hence the error message and the fact that you cannot install the 32bit librairies... the search goes on! First one to find a 64bit distro!
Go!
Hydro-Quebec is salivating...
  #42 (permalink)
Old April 3, 2008, 06:21 PM
SugarJ's Avatar
More info - You can use Server or Workstation to create VM's to run in the Player.
Zlojack, do you have a copy of workstation?
  #43 (permalink)
Old April 3, 2008, 06:22 PM
zlojack's Avatar
No...although if it works in Workstation, no need for player right?
  #44 (permalink)
Old April 3, 2008, 06:33 PM
SugarJ's Avatar
Correct. But with workstation you can install from a boot CD like the Server.
  #45 (permalink)
Old April 3, 2008, 06:34 PM
zlojack's Avatar
Except that Workstation looks like it's not free...
  #46 (permalink)
Old April 3, 2008, 06:44 PM
SugarJ's Avatar
It isn't. But thanks to the wonders of BitTorrent, I'm pulling a copy down now. You can also download an evaluation copy.
None of this would be necessary if they used the signed drivers. Or if we could find a 64bit distro for Player. Player and Workstation both work in Vista 64, why doesn't Server? sigh
  #47 (permalink)
Old April 3, 2008, 07:09 PM
zlojack's Avatar
It is rather silly isn't it.
There must be someone around here who has a 64-bit distro that they could turn into a usable file with Server
  #48 (permalink)
Old April 3, 2008, 09:12 PM
SugarJ's Avatar
It is my intention to make a 64bit VM I can then use with Player. If I succeed, I'll let you know.
Edit:
I just realized I could probably create the VM using Server on my fiancee's machine and copy it over. But it will have to wait until Sunday, headed out of town right after work tomorrow.
  #49 (permalink)
Old April 3, 2008, 09:35 PM
zlojack's Avatar
No worries. I'll just keep folding with the regular old console (since for some reason I can't even get WinSMP going )
  #50 (permalink)
Old April 4, 2008, 04:31 AM
3.0charlie's Avatar
In order to use FAH with a SMP flavor, you need to setup your rig with a user password; then if you look at the FAH folder you will find a file called install.bat. Execute the file, and type in twice your user password. (Now that's when my poor memory kicks in: I think you have to create a FAH shortcut and add the -smp flag to the shortcut target - or is this -smp flag only added under Linux? I honestly don't remember. Try it, you never know) Then start FAH.
