Old April 20, 2012, 01:48 PM
Default Updated GPU folding guide?
Hey guys, starting to fold again now that the GPUs have been moved downstairs!
Is there an updated guide for folding on GPUs? I just installed from the F@H website and my first WU took me 2 days good for 2500 pts .... let's just say I was a little disappointed...any flags I'm missing?
Using a GTS450 and just bought 2x GTX560Ti
Thanks!
Old April 20, 2012, 01:50 PM
sswilson's Avatar
What are you using as a client? The V7 client is easy peasy.... no flags required, and no work to set it up so long as you're not running a 680....
Old April 20, 2012, 02:20 PM
LoTech's Avatar
I must say I am completely new to folding. I started by downloading the v7 client and I'd say its as easy as point and clic. Very intuitive. I do run win 7 64 bit and have found that leaving the monitor on 24/7 stops the gpu clients from reporting failures. I am running 2 pc's. Both are on Asus boards, 1 is a i7 2700 and the other i7 3820. The 3820 also has 2 gpu's. 1 is a gts 450 the other a gtx 560 ti SC. On the 2700 there is only one gpu, a gtx 560 ti 448 UC. Both machines report a 24/7 PPD of about 23k to 30k depending on units received. Happy folding!!
Old April 20, 2012, 03:42 PM
Where do you guys find this v7 client?
(Sorry for being lazy I have a final paper due tonight and I'm taking multiple HWC breaks )
Old April 20, 2012, 03:54 PM
3.0charlie's Avatar
https://fah-web.stanford.edu/project...ki/BetaRelease
Hydro-Quebec is salivating...
Old April 20, 2012, 04:09 PM
Thanks charlie
Yeah ... was still using the systray version. I'll give that a try tonight or tomorrow.
Is nVidia GPU Linux folding a viable option? I'd rather pop my GPUs in the Linux server vs my Win server 2008.
Old April 20, 2012, 04:10 PM
3.0charlie's Avatar
Not that I know of.
Old April 22, 2012, 07:02 PM
MARSTG's Avatar
You can use fah gpu tracker V2. You can use the autodetect function and additionally you can use -advmethods flags even for gpu client. You might get large units and the gpus will run hot so be prepared with good cooling. You can extrapolate some results from my experience.
My GT430 (96 SPs @ 730MHz) was doing as in the picture with the Fermi optimized client
Old April 25, 2012, 08:55 AM
The FAH client 7 keeps failing to get a new WU every time after it's done the current one and I have to mess around with it, stopping/restarting every time to get it to pick up work again. Anyone else getting similar issues?
Old April 25, 2012, 10:15 AM
Tim_H's Avatar
Is it sleeping? there was a thread not long ago about gpu sleeping when it was done a wu. Might help?
http://www.hardwarecanucks.com/forum...completed.html
Folding@Home Windows and PS3 Starter's Guide: FAQ, Links to Guides chrisk HardwareCanucks F@H Team 28 April 4, 2014 06:41 PM
SMP install guide for Folding @ Home SugarJ HardwareCanucks F@H Team 41 March 16, 2012 11:10 AM
6 GPU folding computer/need help with dedicated folding machine Silent_Avenger New Builds 11 December 25, 2011 02:17 PM
folding@home thread. Updated as necessary - _dangtx_ _dangtx_ HardwareCanucks F@H Team 628 June 25, 2010 08:48 PM
Quick guide to using your PS3 for Folding@Home chrisk HardwareCanucks F@H Team 22 May 2, 2010 09:16 AM
