Old February 26, 2012, 10:23 PM
Shadowmeph's Avatar
Default kakostats show low points for me
It is strange I looked on kakostats and it shows my 7 day points at 22000, but when I looked at hfm it is showing me 79517.1 with 26517 credit whats going on? I was usually about 500000 for 7 days
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old February 27, 2012, 12:26 AM
SwingOP3's Avatar
EOC Stats confirms you've got some issues - 22,706 points on Feb 24 and 259,234 points on Feb 17.
Something is not right, sir.
Edit: Why are your folding sig numbers all wrong? They don't match your's or the teams current stats.
Old February 27, 2012, 03:45 AM
chrisk's Avatar
Folding Captain
Hey Shadow...looks like you barely have any points at all:
Shadowmeph - User Summary - EXTREME Overclocking Folding @ Home Stats
You need to triple-check your team and user info in the folding client itself.
Your sig stats are linked to a picture, and not using the proper BB code as well.Your sig code should look like the attachment below (but with your folding name instead of mine)
Fold for team #54196
Old February 27, 2012, 03:46 PM
Shadowmeph's Avatar
I noticed a client.cfg~ which I am thinking is a back , when I opened it everything looks the save accept for
the client.cfg~ has this different
bigpackets=big
extra_parms= -bigadv -smp
local=12
[http]
active=no
host=127.0.0.1
port=8080
usepasswd=no
[core]
addr=
and the client.cfg shows this
bigpackets=big
extra_parms= -bigadv -smp 16
local=28
[http]
active=no
host=127.0.0.1
port=8080
usepasswd=no
[core]
addr=
I am sure that the smp16 isn't a big deal but what about the local settings? I am not even sure what that is
and according to properties the client.cfg was last accessed onthe dates Wed 04 Jan 2012 01:23:59 PM PST
Dam no wonder I went from 46th to 49th :(, I used to alwasy go to Kakostats every morning to check but for the last little while I have been so caughtup in other things I had forgotten until yesterday.
As for the sig ...OHMYGOD I never even noticed it not shanging I feel pretty silly now
Folder :
Old February 28, 2012, 07:13 AM
Tim_H's Avatar
I don't recognize those lines, that said it's been a while since I've looked at a client.cfg file
Have you tried running the client with -configonly to try and rebuild the config file?
Have you checked your passkey to make sure it's right?
I have one on a laptop(i7-2820QM) I have access to right now. This is what it looks like.
Code:
[settings]
username=Tim_H
team=37412
passkey=###########################
asknet=no
machineid=1
bigpackets=normal
local=160
[http]
active=no
host=localhost
port=8080
usereg=no
[power]
battery=yes
[clienttype]
type=3
[core]
addr=
Edit: found this link Client.cfg - FaHWiki
S: local=213
N: This is not actually a configuration setting, this is the value of completed Work Units
which the client reports in the FAHlog.txt file as:
[20:58:03] + Number of Units Completed: 213
It also says not to manually edit the client.cfg file.
My points are crazy low! great_big_abyss HardwareCanucks F@H Team 9 February 11, 2012 04:47 PM
Netflix . Laymens movie review..I'll show you mine if you show me yours Mark Off Topic 8 September 9, 2011 05:56 AM
P2684 better points now!!! Charloz24 HardwareCanucks F@H Team 26 May 16, 2011 09:22 AM
2 WU, 50k points whited HardwareCanucks F@H Team 9 May 10, 2010 10:15 AM
Where did all my points go? Nodscene Off Topic 11 November 26, 2008 09:40 AM
