Old January 30, 2012, 03:52 PM
Also add in the equation the noise and heat generated by the GPUs
yeah is like you are at the airport and jets are taking off. My rig was folding at a given moment with a 9800GX2, a GTS250 and a 9800GTX+ (all these 3 cards were run off of a 650W PSU). it is fine as long as you keep your headphones on but when you take them off, that is another story. I sold all the cards and I am staying only on CPU folding it is much quieter and much more energy efficient. if you want cpu folding a good start is a rig with a core i7 2600k. Phenom II X6@4GHz and i5 2500k@4.5 GHz generate about 14k PPD, an i7 2600K@4.5 GHz is doing around 27k PPD so you have a good idea of what to expect.
Old January 30, 2012, 04:48 PM
I just sold of my two dual gtx 560 / i7 folding rigs and replaced them with two 4p MC rigs..
the heat is down, but the noise is up..
i get about 400k every two days with the bigadv units..
-joe
Old January 31, 2012, 06:27 AM
Hm, I never really thought about the noise but that would be a major factor for me. I don't want my apartment filled out with the sound of video cards, it would drive me and my GF crazy. I think that I would just save my pennies and go for a 2P rig in the future, it seems like it would be more cost efficient in the end with less noise as well.
I see a lot of people posting saying that they bought their 6128 and 6174 procs for $600 each but when I check on line at memoryexpress or ncix they are $1000 each. Are people getting these off ebay or something?
Old January 31, 2012, 07:10 AM
CoolHandL's Avatar
6128's are more like $150 each and 6174s can be had for $497, yes from ebay. Ask a few 2&4p owners for the seller they bought from.
Skywalker - Q6600(GO)+P5Q Pro turbo+HD5870+HX750
Hansolo - X4 925+M4A785-M+HD6850+OCZ500W
Chewbacca - Q6600(GO)+P5G41-M+OCZ500W
DEATHSTARMini - Zotac N330 mini ITX
Old January 31, 2012, 07:35 AM
bissa's Avatar
maybe for you guys. but folding with my 560 TI twin frozr, the CPU cooler fans are louder than the GPU fans, and the sound from those are a little quieter than when my HDD spins up full rev.
Old January 31, 2012, 07:56 AM
Wow, that's much cheaper than I was expecting! With 6128's for $150, I could build a 4p system for an okay price.
Old January 31, 2012, 10:43 AM
The thing I don't miss from GPU folding is the heat
I used the raven cases (which vents the cards up vertically) and it was like an oven
true it wasn't as loud.. but it was HOT
I have some BNIB Interlagos for sale (cheeep) and I can throw in some memory (ECC 2gb x 16 sticks) :)
-joe
Old January 31, 2012, 03:05 PM
I think the multi processor systems will have to hold on for a little while as I am going to be getting a new graphics card for my main system first so it may be a while. Thanks for the info everyone!
  #19 (permalink)
Old February 7, 2012, 03:15 PM
So I picked up a gigabyte 7950 windforce OC and have put it to work folding :) Sadly my case is pretty small so I can't fit my old 4870 in at the moment. I am going to try to move some hard drives around and see if I can fit it in to get some extra folding power. *Fingers Crossed*
  #20 (permalink)
Old February 7, 2012, 07:38 PM
Silent_Avenger's Avatar
TBH you'd be better off just running smp on your i7 vs the amd cards. At minimum if you want to do gpu folding go nVidia you get major points from nVidia. Even if you're planning on running the cards along side smp on the cpu it still wouldn't be worth it in a ppd/watt point of view. Just my 2 cents.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Absolute best Folding GPU for Folding CasheKicker HardwareCanucks F@H Team 21 February 14, 2012 09:54 AM
Folding client V7 - SLI - Cannot use system during folding..fix? Jake_HT HardwareCanucks F@H Team 8 January 18, 2012 10:17 AM
6 GPU folding computer/need help with dedicated folding machine Silent_Avenger New Builds 11 December 25, 2011 01:17 PM
folding on 3 core / core free for gpu folding phil3_66666 HardwareCanucks F@H Team 12 January 11, 2010 06:07 PM
Get me folding! KrisMRT HardwareCanucks F@H Team 12 September 18, 2009 11:37 PM
