  #61 (permalink)
Old January 26, 2012, 01:38 PM
MARSTG's Avatar
i didn't use nohup but I detached them. i verified some time ago they were both at 20%. i guess credit is coming at next update if they took other WU's to process. The other instance was at 58%. How can I tell which project is being run at any given time? from the window that is running?
  #62 (permalink)
Old January 26, 2012, 01:40 PM
great_big_abyss's Avatar
Anybody figure out how to connect using HFM.net to monitor? I'd like some help with this. I'm kind of a noob at remote access!
  #63 (permalink)
Old January 26, 2012, 01:44 PM
dandelioneater's Avatar
I use ''screen'' to start the client then alt-f4 out of the terminal and it keeps goin. easy!
  #64 (permalink)
Old January 26, 2012, 01:57 PM
MARSTG's Avatar
yeah, it was explained here, HP Cloud Services HFM.NET client setup Tim_H posted it first beacuse this is the second time you ask for it. You need to install Apache and set some permissions when the server sees your IP to give you access. Issue is the guide says something about moving the fah directory and this is where I lost it and forgot about it.
  #65 (permalink)
Old January 26, 2012, 02:00 PM
Ah, my bad. Must've missed Tim_H's post. Thanks though.
  #66 (permalink)
Old January 26, 2012, 02:16 PM
Tim_H's Avatar
the commands are just below the screenshots to do this. there might be some permission issues leaving it in the root home dir, that's why it's moved to the root (my guess).
you are going to need to stop folding while you move the directory, then start it again after it's moved.
the command
Code:
mv folding /
will move the folding directory to the root (/)
next they say
Code:
cd /
This is to move to the root
then
Code:
dir
is to display the directories in your current location to verify that the folding directory in the right location
Then change to the folding directory and start it as you normally do
edit*forgot to mention to go into the folding directory
  #67 (permalink)
Old January 26, 2012, 03:21 PM
3.0charlie's Avatar
As a trusted beta tester, we’re offering you the opportunity to invite five friends to try out our cloud compute and cloud storage services. Five of your closest friends will be pre-qualified for our private beta and will receive invites immediately. This is your chance to get them priority access to our exclusive, free private beta.
1st 5 PMs get the how-to.
1 down, 4 to go.
Hydro-Quebec is salivating...
  #68 (permalink)
Old January 26, 2012, 03:48 PM
lowfat's Avatar
I don't get how that invite thing works. I got the same email. But there is no referral link or anything.
Mael
Big Lian Li
Forever Alone
  #69 (permalink)
Old January 26, 2012, 03:53 PM
3.0charlie's Avatar
No, but read carefully. HP is asking to add something in a specific field. I know DT tried it and it worked - to an extent.
  #70 (permalink)
supaflyx3's Avatar
same here lowfat.
Absolute best Folding GPU for Folding CasheKicker HardwareCanucks F@H Team 21 February 14, 2012 10:54 AM
Folding client V7 - SLI - Cannot use system during folding..fix? Jake_HT HardwareCanucks F@H Team 8 January 18, 2012 11:17 AM
6 GPU folding computer/need help with dedicated folding machine Silent_Avenger New Builds 11 December 25, 2011 02:17 PM
folding on 3 core / core free for gpu folding phil3_66666 HardwareCanucks F@H Team 12 January 11, 2010 07:07 PM
CPU folding BT! HardwareCanucks F@H Team 9 December 2, 2008 11:20 PM
