  #41 (permalink)
Old January 26, 2012, 07:16 AM
supaflyx3's Avatar
Thanks for this! signed up, hopefully ill get it going pretty quick.
  #42 (permalink)
Old January 26, 2012, 07:20 AM
Originally Posted by SwingOP3 View Post
Hey MARSTG, are you getting those ppd estimates using a smp calculator or have you found a way to monitor using HFM.net?
fah bonus point calculator Folding@home Bonus Point Calculator
I would say is working fine for SwingOp3 as he has 2 updates today of over 20k points each.
  #43 (permalink)
Old January 26, 2012, 08:56 AM
Tim_H's Avatar
speaking of monitoring
the guys at evga have a how-to
HP Cloud Services HFM.NET client setup
I haven't set it up yet, Hopefully I have some time tonight to try it out. doesn't look to bad though
  #44 (permalink)
Old January 26, 2012, 08:58 AM
lowfat's Avatar
Thank you HP
  #45 (permalink)
Old January 26, 2012, 09:08 AM
great_big_abyss's Avatar
up and running using the evga win 7 system.
How can I use HFM.net to monitor them?
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
  #46 (permalink)
Old January 26, 2012, 09:27 AM
Arinoth's Avatar
Which setup method did you use again Lowfat?
  #47 (permalink)
Old January 26, 2012, 09:29 AM
lowfat's Avatar
I feel like I'm wading in way over my head.
BUT
A quick search brought up a guide on OCN Quick and Dirty HPCS F@H Setup Guide
I used this method. But not all instances are strong enough to complete a P6903 in time. Had to turn one of them them on to regular SMP.
  #48 (permalink)
Old January 26, 2012, 10:02 AM
Arinoth's Avatar
Hmm I'm good until the part where I need to SSH in, I tried to use PuttY and the public IP address it gave me but it said the connection timed out.
  #49 (permalink)
Old January 26, 2012, 10:18 AM
lowfat's Avatar
Try using the application they suggested in the thread maybe. I use Terminal in OSX so I can't help w/ Putty since I've never used it.
  #50 (permalink)
Old January 26, 2012, 10:20 AM
Arinoth's Avatar
The application they use is a Linux based terminal emulator, plus I'm stuck at the actual figuring out how to connect part. The rest of it makes sense...
It's saying you need to have a copy of linux to essentially do this, as you need to use the Linux Terminal for their directions to work (either in VMware or fully installed as an OS)
Absolute best Folding GPU for Folding CasheKicker HardwareCanucks F@H Team 21 February 14, 2012 09:54 AM
Folding client V7 - SLI - Cannot use system during folding..fix? Jake_HT HardwareCanucks F@H Team 8 January 18, 2012 10:17 AM
6 GPU folding computer/need help with dedicated folding machine Silent_Avenger New Builds 11 December 25, 2011 01:17 PM
folding on 3 core / core free for gpu folding phil3_66666 HardwareCanucks F@H Team 12 January 11, 2010 06:07 PM
CPU folding BT! HardwareCanucks F@H Team 9 December 2, 2008 10:20 PM
