  #231 (permalink)
Old February 14, 2012, 07:28 AM
Where in the web console? I have been trying to follow the tutorial below
Quick and Dirty HPCS F@H Setup Guide
In the image below it appears that you can click hpdefault.pem and download the file there but when I click the "Connect to Server" button I only see text that says "Locate the private key for the key pair named hpdefault"
Thoughts?
  #232 (permalink)
Old February 14, 2012, 07:33 AM
great_big_abyss's Avatar
The instructions you're using are if you're accessing through Linux.
If you're currently using windows, use the following instructions:
EVGA Windows HPCS Setup Guide
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
  #233 (permalink)
Old February 14, 2012, 07:44 AM
Thoughts?
click on the blue thing HPDEFAULT.PEM
-joe
  #234 (permalink)
Old February 14, 2012, 07:45 AM
Tim_H's Avatar
I know I don't have the option to download them again. Mine are grey'd out now. Hopefully I don't loose them. best bet would be to contact support
  #235 (permalink)
Old February 14, 2012, 07:52 AM
-joe
Hi Joe,
The screenshot is from the tutorial, I don't have the option to download this file. I believe when I created the keypair there was a huge character string that I saved to another word document. Perhaps I have to save this as another file type and use it for Putty.
  #236 (permalink)
Old February 14, 2012, 07:58 AM
Hi GBA,
THanks for the tip, I have been following this guide but it is also asking me to select my saved PPK file which I don't appear to have. :( I have some key that I saved when I created the keypair but when I tried to save it as a .PPK file to use in Putty it doesn't accept it.
  #237 (permalink)
Old February 14, 2012, 08:02 AM
You create the key file using puTTygen, save it,
Open PuTTYgen and select Conversions and Import Key. Select hpdefault.pem and Save private key. Ignore the warning.
I saved the files as USWest2-AZ2.ppk and USWest2-AZ1.ppk because only one key is needed for each compute cluster location.
Close PuTTYgen.
then load it into puTTy under
connection --> SSH --> Auth --> Browse
  #238 (permalink)
Old February 14, 2012, 08:16 AM
Thanks for the clarification, but the problem that I am having is getting the hpdefault.pem file. When I created my keypair it said to copy the keypair text portion and use it to create the pem file. It doesn't appear to let me download the pem file and I'm not sure how to create the pem file on my own to load into PuTTYGEN as when I try to save the file as a .pem file and open with the "import key" PuTTYGEN doesn't recognize it saying it "couldn't load private key"
  #239 (permalink)
Old February 14, 2012, 08:43 AM
Tim_H's Avatar
so you never downloaded the hpdefault.pem file? I would contact HPCS support to get a new one
edit: after you get the hpdefault.pem file, you have to convert it to a ppk. it is the 5th(ish) paragraph down in the guide.
Close PuTTYgen.
  #240 (permalink)
Old February 14, 2012, 08:53 AM
No, I wasn't able to download the .pem file. I did end up calling HPCS support and they walked me through. It turns out that I was only copying the key but not the "-----BEGIN RSA PRIVATE KEY-----" and "-----END RSA PRIVATE KEY-----" portions when saving the file. I created a new keypair and copied all the info and it worked :) Now to go on to finish setting this up :(
Thanks for all the advice everyone!
Absolute best Folding GPU for Folding CasheKicker HardwareCanucks F@H Team 21 February 14, 2012 09:54 AM
Folding client V7 - SLI - Cannot use system during folding..fix? Jake_HT HardwareCanucks F@H Team 8 January 18, 2012 10:17 AM
6 GPU folding computer/need help with dedicated folding machine Silent_Avenger New Builds 11 December 25, 2011 01:17 PM
folding on 3 core / core free for gpu folding phil3_66666 HardwareCanucks F@H Team 12 January 11, 2010 06:07 PM
CPU folding BT! HardwareCanucks F@H Team 9 December 2, 2008 10:20 PM
