Old January 25, 2012, 12:26 AM
bissa's Avatar
yes, that's a good speed for that WU. points for SMP are given after it's been turned in, and after the first 10 WUs, you will get a quite significant point bonus. it takes a bit to get running right, but once it is, avoid fiddling.
Old January 25, 2012, 01:31 AM
bigFOIG's Avatar
RunningNoFrameTimes... anyone know what that is?
Old January 25, 2012, 06:04 AM
3.0charlie's Avatar
Is the rig overclocked?
Hydro-Quebec is salivating...
Old January 25, 2012, 07:32 AM
Tim_H's Avatar
You will see that when you are just starting a WU or if you restart the client. Once you have done a few (3 I think) it will show as running.
Old January 25, 2012, 04:28 PM
bigFOIG's Avatar
Yes, it's an i7 930 overclocked to 4.4ghz. It was a tiny bit unstable, so I dropped it down to 4.2ghz to stabilize it and cool it a few degrees.
Well, I deleted all my previous FAH folders and installations and I'm now using FAH Control. Running SMP and GPU along with it now and not a single problem.
Old January 25, 2012, 05:11 PM
3.0charlie's Avatar
FAH is the best stability Program out there. You can be 'stable' all you want with any kind of synthetic app, but folding will find the unstable rig.
Bigadv points changes Alpine HardwareCanucks F@H Team 40 July 24, 2011 04:39 PM
All Points Bulletin headsh0t Gaming 6 July 12, 2010 12:42 AM
2 WU, 50k points whited HardwareCanucks F@H Team 9 May 10, 2010 10:15 AM
Where did all my points go? Nodscene Off Topic 11 November 26, 2008 10:40 AM
25 ncix points jay51 Off Topic 10 October 7, 2008 11:17 AM
