-   HardwareCanucks F@H Team (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/)
-   -   PPD considerably lower. (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/50425-ppd-considerably-lower.html)
great_big_abyss January 13, 2012 09:09 AM
So I've noticed over the last few days that my PPD on both of my folding machines has dropped noticeably.
My primary machine is listed under 'my system specs'. I'm not able to check what work units are being worked on at the moment on that machine.
My secondary machine is running an Intel Xeon W3520 @ 2.67GHz. It's currently working on WU P7507 (R0, C90, G93). TPF is about 27min, and PPD is 1369.3. A few days ago I was getting about 7000-8000 PPD out of this machine. What gives?
[16:51:31] + Processing work unit
[16:51:31] Core required: FahCore_a3.exe
[16:51:31] Core found.
[16:51:31] Working on queue slot 04 [January 12 16:51:31 UTC]
[16:51:31] + Working ...
[16:51:31]
[16:51:31] *------------------------------*
[16:51:31] Folding@Home Gromacs SMP Core
[16:51:31] Version 2.27 (Dec. 15, 2010)
[16:51:31]
[16:51:31] Preparing to commence simulation
[16:51:31] - Looking at optimizations...
[16:51:31] - Created dyn
[16:51:31] - Files status OK
[16:51:32] - Expanded 2167243 -> 3127236 (decompressed 144.2 percent)
[16:51:32] Called DecompressByteArray: compressed_data_size=2167243 data_size=3127236, decompressed_data_size=3127236 diff=0
[16:51:32] - Digital signature verified
[16:51:32]
[16:51:32] Project: 7507 (Run 0, Clone 90, Gen 93)
[16:51:32]
[16:51:32] Assembly optimizations on if available.
[16:51:32] Entering M.D.
[16:51:38] Mapping NT from 4 to 4
[16:51:38] Completed 0 out of 500000 steps (0%)
[17:06:10] Completed 5000 out of 500000 steps (1%)
[17:27:05] Completed 10000 out of 500000 steps (2%)
[18:13:44] Completed 15000 out of 500000 steps (3%)
[18:59:51] Completed 20000 out of 500000 steps (4%)
[19:46:08] Completed 25000 out of 500000 steps (5%)
[20:33:04] Completed 30000 out of 500000 steps (6%)
[21:13:22] Completed 35000 out of 500000 steps (7%)
[21:27:13] Completed 40000 out of 500000 steps (8%)
[22:01:05] Completed 45000 out of 500000 steps (9%)
[22:34:30] Completed 50000 out of 500000 steps (10%)
[23:23:06] Completed 55000 out of 500000 steps (11%)
[23:53:31] Completed 60000 out of 500000 steps (12%)
[00:14:54] Completed 65000 out of 500000 steps (13%)
[00:39:55] Completed 70000 out of 500000 steps (14%)
[00:53:07] Completed 75000 out of 500000 steps (15%)
[01:24:22] Completed 80000 out of 500000 steps (16%)
[02:07:16] Completed 85000 out of 500000 steps (17%)
[02:34:16] Completed 90000 out of 500000 steps (18%)
[02:47:28] Completed 95000 out of 500000 steps (19%)
[03:00:59] Completed 100000 out of 500000 steps (20%)
[03:14:16] Completed 105000 out of 500000 steps (21%)
[03:27:32] Completed 110000 out of 500000 steps (22%)
[03:42:07] Completed 115000 out of 500000 steps (23%)
[04:13:10] Completed 120000 out of 500000 steps (24%)
[04:32:10] Completed 125000 out of 500000 steps (25%)
[04:45:23] Completed 130000 out of 500000 steps (26%)
[04:59:05] Completed 135000 out of 500000 steps (27%)
[05:12:18] Completed 140000 out of 500000 steps (28%)
[05:25:30] Completed 145000 out of 500000 steps (29%)
[05:40:08] Completed 150000 out of 500000 steps (30%)
[06:26:00] Completed 155000 out of 500000 steps (31%)
[06:46:11] Completed 160000 out of 500000 steps (32%)
[07:00:03] Completed 165000 out of 500000 steps (33%)
[07:13:17] Completed 170000 out of 500000 steps (34%)
[07:26:29] Completed 175000 out of 500000 steps (35%)
[07:40:02] Completed 180000 out of 500000 steps (36%)
[07:53:19] Completed 185000 out of 500000 steps (37%)
[08:07:04] Completed 190000 out of 500000 steps (38%)
[08:26:49] Completed 195000 out of 500000 steps (39%)
[08:57:24] Completed 200000 out of 500000 steps (40%)
[09:37:33] Completed 205000 out of 500000 steps (41%)
[10:17:57] Completed 210000 out of 500000 steps (42%)
[10:45:01] Completed 215000 out of 500000 steps (43%)
[11:30:18] Completed 220000 out of 500000 steps (44%)
[12:14:54] Completed 225000 out of 500000 steps (45%)
[13:00:05] Completed 230000 out of 500000 steps (46%)
[13:45:40] Completed 235000 out of 500000 steps (47%)
[14:26:42] Completed 240000 out of 500000 steps (48%)
[14:51:32] Completed 245000 out of 500000 steps (49%)
[15:33:54] Completed 250000 out of 500000 steps (50%)
[15:48:11] Completed 255000 out of 500000 steps (51%)
sswilson January 13, 2012 09:40 AM
4 core smp right?
We had a pile of really short SMP units (were something like 88 points pre-bonus) for 2 - 3 days, those probably affected PPD (mine seems to be down aprox 5K total).
Tim_H January 13, 2012 11:05 AM
have you tried stopping and restarting the client? I don't see anything in the log that indicates a problem.
I did have an issue the other day where the affinity was set to only 2 cores on my machine (little mistake on my part) and I couldn't figure it out. fixed that and my times dropped.
great_big_abyss January 13, 2012 12:50 PM
Originally Posted by sswilson (Post 589905)
4 core smp right?
Yes, 4 core smp. It's not running them any faster though. Is this normal?
great_big_abyss January 13, 2012 12:55 PM
I check that under my client config, right? what should i look for?
Tim_H January 13, 2012 01:47 PM
no it's setting under windows task manager. you can right click on a process and set the 'Affinity' to limit the process to specific cores. if you haven't changed this in the past it's likely not the issue.
What are the temperatures of the system. could be CPU throttling.
chrisk January 13, 2012 02:28 PM
I have used a program called Prifinity to keep my linux vm clients in a high priority state in the past:
PriFinitty 2 - Edgemeal Software
You could try running it, and making sure the core process is in high priority.
great_big_abyss January 13, 2012 03:22 PM
Thanks. Checked it (didn't know you could do that...learn something new every day) and the affinity limits are just fine.
Again, thanks. I'll let it run over the weekend and see if it rectifies itself.
chrisk January 13, 2012 03:35 PM
If your affinities are fine when you checked manually I doubt Prifinity will do a whole lot. Still worth a try anyways and report back.
