3.0charlie, do you have a post with more info about your ram, bios and linux settings you used in your build? I'm at 335k now on a 6903 but I want to figure out if there is a setting that can get me a little bit more. My os is ubuntu 10.10 server with no updates installed following musky's guide.
I have most of the extra SAS controllers and PCIe stuff turned off in bios. The CPU area of the bios looks like this:
Code:
* GART Error Reporting [Disabled]
* Microcode Update [Enabled]
* Secure Virtual Machine Mode [Disabled]
* PowerNow [Disabled]
* ACPI SRAT Table [Enabled]
* CPU DownCore Mode [No Leveling]
* CPU prefetch [Enabled]
* IO prefetch [Enabled]
* Probe Filter [Enabled]
* HTC [Disabled]
