-   HardwareCanucks F@H Team (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/)
-   -   CPU choices (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/50277-cpu-choices.html)
jtktam January 9, 2012 05:57 PM
CPU choices
Hi... new to the boards..
I picked up a few AMD cpus and didn't know what I should be using to get maximum ppd..
I have the following parts
4x AMD Opteron 6272 - 2.4 GHz Sixteen Core <-- Interlagos
2x AMD Opteron 6174 - 2.2 GHz Twelve Core <-- Magny-Cours
8x AMD Opteron 6134 - 2.3 GHz Eight Core <-- Magny-Cours
1x SUPERMICRO AS-4042G-6RF barebone 4P g34 server..
4x Kingston 16gb ECC DDR3 memory (2x8gb kits)
8x Kingston 4gb ECC DDR3 memory (2x2gb kits)
My original plan was to go 64 cores (using the 6272s) with 64gb of RAM.. but I read that the MC will do better job? will the 32 MC cores be faster or equal to 64 IL cores?
I am also concern about heat and watt draw.. since I will eventually have 3x 4p servers running.. I can sell the IL now for a good price (enough to get a second barebone) and use 2x 4p MC ??
I guess now I can go with the 32gb in quad channel in the 4p.. probably can get away with going dual channel on the 2p
-joe
SugarJ January 9, 2012 08:20 PM
Thread moved to the Folding @ Home forum, where it will get the proper exposure. I can't advise you on 2P/4P solutions, but there are others on here who can.
Shadowmeph January 9, 2012 08:20 PM
I think that there is some statistics ( but I am not totally sure ) in this part of the Forums here HardwareCanucks F@H Team - Hardware Canucks
aw shows you how slow I am at typing threat was moved to the right forum :haha::thumb:
4DoorGTZ January 9, 2012 09:03 PM
Clock for clock the IL is faster then the MC, but it's not proportional to the core and wattage increase. So if the goal is the highest ppd per rig a faster il would be better then mc but it's going to draw more power.
Someone also said 64core folding leaves something t o be desired and it would be better to do 2x32core instead, dunno 48core seems fine to me. And you're not going to need 64gb of ram, I haven't seen my rig use more then 4.5gb, but I know first hand 1gb sticks are hard to find, so the cheapest lowest latency sticks you can find will do, quad channel 16 sticks.
Either way that kinda horsepower listed should get you ontop of the ppd list, climbing the point ladder very quickly.
jtktam January 10, 2012 03:53 AM
Since I haven't actually started the built and I am waiting for the 4x NH-U9DO A3 to come in, I really want to nail this down
I had ordered the 4xIL before I found the deal on the 8xMC, that's how I ended up with a dozen CPUs :P
The memory I got, they are on the tested memory list for the supermicro board and they are DR, all of the ECC memory I seen are about $10/gb regardless of size.. I have to see if the board will run stable on dual channel though.. since I only have 4 kits
What kind of PPD you getting on your quad rig?
-joe
CoolHandL January 10, 2012 08:19 AM
wow thats a nice cache of CPUS (if ever you need to unload the 2x AMD Opteron 6174, i am in the market for 2...... for my http://www.hardwarecanucks.com/forum...-7-folder.html) Fold on and welcome.
jtktam January 10, 2012 08:55 AM
probably not the 6174s since I am saving those for my ASUS board..
I am looking to rid the IL set though.. it's a matched tray of 4..
-joe
4DoorGTZ January 10, 2012 09:20 AM
-joe
4DoorGTZ[HCF] - User Summary - EXTREME Overclocking Folding @ Home Stats
Looks like between 400kppd and 600kppd depending on wu mix.
You will take a performance hit only running dual channel, I saw a performance bump of about 3% going from CL9 to CL7 both in quad channel.
jtktam January 10, 2012 09:27 AM
I made a mistake ordering the ram.. got 4 kits of 2x8gb instead of 8 kits of 2x4gb ..
so I will probably use the 4 kits in my asus build up and buy the 8 kits (ouch)
-joe
CoolHandL January 10, 2012 10:00 AM
-joe
Yeah i think the IL will be a stretch out of my Price range (plus i'm only building a dual headed monster, A quad socket board would eat most of my budget)
