Old January 5, 2012, 09:32 PM
Shadowmeph's Avatar
I am pretty sure the ones on newegg.ca are only 4 ram slots not 8
Old January 5, 2012, 09:34 PM
Shadowmeph's Avatar
how much does That bulldozer chip produce?
I wished that I could just totally remove my vid card and successfully get access to my folder.
Old January 5, 2012, 09:48 PM
MARSTG's Avatar
actually that model is the one with the 8 slots. but why would it matter? just use higher density memory modules.
Old January 5, 2012, 09:56 PM
Why can't you? very easy to do a headless setup
Old January 5, 2012, 10:22 PM
Shadowmeph's Avatar
I can't access my terminal on the folder I can access the desktop move my mouse around but there is nothing on the desktop or even any of the status bars, I even change from gnome to the xfce hoping that would make it easier but still the same thing .
Old January 5, 2012, 10:26 PM
if your running linux install ssh for terminal access then install "screen"
Old January 5, 2012, 11:59 PM
Shadowmeph's Avatar
Cool I will check that out thankyou
Old January 6, 2012, 12:41 AM
supaflyx3's Avatar
Then download putty on your client, connect using SSH. After that you login like you normally would in terminal and you're rocking. Screen allows you to run applications after you've closed terminal, to recover a screened application i believe the command is "screen -r *process ID*"
  #19 (permalink)
Old January 6, 2012, 05:41 AM
3.0charlie's Avatar
Between 55k and 95k, depending on the WU folded. Once found to be stable, this rig will be offered in the BST area.
I'm sure you'll work it out. I've installed xrdp on my rigs and use Windows RDC to remotely control the rigs.
Hydro-Quebec is salivating...
  #20 (permalink)
Old January 6, 2012, 06:33 AM
stoanee's Avatar
Name suggestion=Pinball Wizard
heatware
'Deux' 3.0charlie HardwareCanucks F@H Team 194 December 23, 2011 09:36 PM
Cheap PC for Brother elimtl New Builds 9 April 21, 2011 04:12 PM
brother computer CTA New Builds 11 December 22, 2010 07:38 PM
Input on rig for my brother Waldie New Builds 35 February 19, 2010 07:17 PM
New build for my brother.. Realityshift New Builds 7 July 17, 2009 07:26 PM
