-   HardwareCanucks F@H Team (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/)
-   -   is it possible to use a laptop HD to fold? (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/49774-possible-use-laptop-hd-fold.html)
Shadowmeph December 26, 2011 12:56 PM
I have decided to change my FOlding\media server rig into a dedicated folding machine so I am going to pull all of my HDs out and install a little seagate 60gb laptop HD then it should be a little cooler . I am just wondering though if that is enough to fold with, I want to use that hard drive and try the Kraken but I am not sure where to find out more info on what needs to be installed ( Linux distro?)
Funning thing also, I was running the FAH inside a VMware ( linux) but for some reason I could never even reach half of my main PC so I installed the beta FAH version 7.138 and now the estimated PPD is around 14689 which is three times as much as running the Linux client in VMware .
this machine sure does produce enough heat ( I have only a single cpu running right now) to heat my room with the Window almost fully open lol.
3.0charlie December 26, 2011 01:12 PM
HDD will be fine for folding.
Use this guide to set up Linux folding, and TheKraken. Ubuntu Desktop Installation Guide for F@H - [H]ard|Forum
Shadowmeph December 26, 2011 01:18 PM
Thank you Charlie
Shadowmeph December 26, 2011 05:06 PM
Sure sucks trying to make a USB 320gb harddrive into a Linux boot because I don't have a cd drive and only one tiny 1gb usb flash pen lol
enaberif December 26, 2011 05:15 PM
UNetbootin - Homepage and Downloads
Shadowmeph December 26, 2011 05:58 PM
Originally Posted by enaberif (Post 583521)
thanks I was trying that stupid pen install thing but it never did qork lol.I FInally just rebooted after the Ubuntu install and I really don't like what they did to Ubuntu, but it doesn't matter since this is going to be a folding unit :)
frontier204 December 26, 2011 07:36 PM
I'm concerned that a hard drive's heat output is being factored into your F@H considerations :shok: unless of course what you're switching from is one of those really old 80-160GB drives that make more noise than stock CPU fans. Unless you somehow find a way to crunch all of your work units in less than 15 minutes a piece, the HDD won't bottleneck your folding. (I've even tried folding off USB 2.0 sticks for fun.)
My F@H rigs aren't half a productive as what you're probably trying for, but my choice of distro has never made a noticeable effect on performance. If you want to compare distros with performance, Phoronix every so often does a performance review on Linux distros with all hardware the same.
I'm running OpenSUSE for my server / F@H combo because the Yast configuration utility is handy when you get used to it.
A 1GB USB drive is more than enough if you want to use one of the Ubuntu Live CD installs, which come in at under 800 MB. I've used the installer from Boot and run Linux from a USB flash memory stick | USB Pen Drive Linux along with a normal Ubuntu Live CD ISO. I've found a temperamental BIOS is the biggest issue trying to install Linux from something other than a CD. If you use UEFI BIOS then expect it not to work.
