Folding on Hyper-V 1 Attachment(s) Has anybody done it? I installed this image: Folding@Home - Native Folding Image - LinuxForge.net onto a Hyper-V VM with 4 cores, 2GB of RAM. Underlying hardware is: i5 2500K - 42x multiplier, but otherwise "stock" settings. That means it only runs 4.2GHz when under load. 16GB DDR3-1333 Hyper-V Manager shows 90-95% CPU usage, but on the host (via task manager) CPU usage is basically 0%. F@H logs show that it's doing work though. Apparently task manager doesn't monitor the Hyper-V service. It would appear as though it is working: http://i.imgur.com/k3IzQ.png Now, what's the most ideal settings to enter in the web config? I attached what I'm currently using, but it was just mainly guesses :whistle: |
It's always been the issue with Hyper-V, loading the cores properly. This was never fixed. Why are you using Hyper-V? The VMware image works fine too (use VMPlayer 3.0, and only 3.0) for 100% CPU usage... and your web settings look fine. I'd try enabling Langouste, if it works properly (allows to receive / being folding a new WU while a completed WU is sent). |
Using Hyper-V since that's what I have on my home server, and I have a bunch of "development" servers running within it. Basically it's just my playground :haha: Figured I'd run FAH in it as well (for the winter months), but it has the lowest priority for RAM/CPU. I'm not out to produce crazy PPD numbers or setup dedicated folding farms like some of you guys, just to provide some contribution to the team! Obviously I don't want to run it directly on the host either since that would severely impact performance. Wonder if running a Server 2008 Core Edition would be better? It would at least integrate with Hyper-V properly, lacks a GUI (so less overhead) and I'd assume it could run FAH command-line mode. But from what I gather, folding on Windows isn't the most ideal. It is definitely using the CPU though, as it's running at 4.2GHz. If it was truly idle (as the host OS is showing), then it would be running much slower. |
Well finished 2 WU's now, seem to be getting around 16.5k PPD. GRO-A3 units, P6972. Good/bad? |
I have no idea! Been a while since I folded SMP WUs. Maybe others can chime in. |
very good actually |
On a 6973, I got 14,048 PPD at 4.5GHz, -SMP 3, on VMware. Usually around 20k ppd with 4 cores. |
Hokay, this thread has me thinking.. if you run taskmgr in hyperv (at the bare metal) you can see all the cores, all the ram, etc.. how about running the dos command on the baremetal hyperv install? well.. to answer your question.. i'll probably be installing it on a i7 980x later this afternoon for shits and giggles! lol. |
Anyways, I'm up around 20k PPD now, so obviously things are working fine. |
Well, to answer my own question, yes: it runs fine on the baremetal (free) hyperv server 2008 r2 easy enough. I have no idea what kind of performance it's running.. cause I haven't figured out how to share a directory and stuff.. in order for HFM to connect to the log files. Now to see how the VMs hold up when the system goes to 100%, hehe. This is just on our test servers btw.. wouldn't do this on a customers box. :) |
| All times are GMT -7. The time now is 10:58 PM. |
